I have looked around and can’t find anything pertaining to my problem.
Bought a M1008 and noticed that the hoses were looking a little rotted or swollen. So I decided to replace heater, core lines, upper and lower hoses. Bypass hose, etc.. put a new overflow tank and refill the radiator
Somehow, this has developed into a leak that I cannot find. I have coolant coming from the middle just behind the harmonic balancer. And under the overflow bottle. I first checked all my hoses and all was good all tight not leaking. Try to look at the water pump and don’t see any moisture coming from the top bottom middle or sides. Overflow is tight no cracks etc.
Tried looking on the backside of the radiator and I do see what appears to be a small leak coming from the lower corner. So that is probably where the leak is under the overflow tank.
But I cannot figure out where the leak is coming from that shows below the harmonic balancer. So my question is after replacing all hoses and more than likely building proper coolant pressure. Do you think by doing what I’ve done has somehow caused a failure in the water pump?
there was no leak prior to doing all this
