m1008 no head lights, horn, brake lights or black out lights
gmjunky87
halifax, pa
sorry if this is redundant. started truck. no headlight, signals, brake lights, horn. made sure black out switches were in proper place. tried to turn black out lights on, nothing. checked head light fuse, it's fine (checked fuse with test light). unplugged black out switches and bypassed the switch. still nothing. not sure what else it could be.
jcollings
403
Jupiter/FL
Yeah that fuse and block takes a beating with all the load for the 12 V circuit. Definitely something to watch I'm debating whether to change my block/rewire or not, Is work in progress.
Sent from my SM-G975U using Tapatalk
gmjunky87
halifax, pa
I checked the main junction block on the firewall, it's past the fusible link. I'll have to take the junction apart at the firewall I guess. It seems like it would be something related to the blackout lights that's why I disconnected the plugs on the switches and made two jumper wires for the service light switch. I'm just stumped because I have power on either side of the fuse for the headlight
jcollings
403
Jupiter/FL
So the junction block you have 12 V going into it and 12 V coming out going through the firewall to your fuse block?
gmjunky87
halifax, pa
Yes 12v going out also.
glow plug system works. Voltmeter on dash has never worked. One of the gen lights doesn't work but it's been that way a while ,(i shorter the fusible link once and prob burned out the bulb, I just charge the back battery)
When you turn the key on wait light, oil light, other gen light, water in fuel light come on and go off like normal.
I don't have access to the truck right now but I think I'll take the front battery out and check the wiring (I've been having rodents, truck doesnt get driven often) also start taking apart the bulk head to the firewall apart to clean it. I suck at reading wiring schematics but from older posts I've read i know a lot go through the head light circuit but it's acting like I have the service light switch off even though I have it bypassed.
Also I installed led headlights about 5 years ago to take some load off that circuit.
jcollings
403
Jupiter/FL
LED, Those usually have some kind of driver set up which modifies the whole headlight system correct
gmjunky87
halifax, pa
The led lights didn't take any modification, they were plug and play. I still have the original square fuel filter with all the wiring for the baseplate if that's what you're referring to. Thanks 👍
jcollings
403
Jupiter/FL
I've seen some LED lights that are required drivers and different type of hook up in wiring.
I still have the square fuel filter myself
I hope you get it. Good luck
gmjunky87
halifax, pa
Well, I'm an idiot! after spending hours cleaning grounds, the bus bars, bulk head connection, having the dash apart checking the blackout light relay, poking and prodding it ended up being a simple, idiotic mistake. I put the headlight fuse in the wrong spot after visually checking it. left is how the fuses should be arranged, right is what I did! but the fuse had power in that slot.
while reading this sticky and testing the orange wire at the blackout switch then looking at the picture how the fuse box was laid out i realized my mistake!
never over look the obvious and start with the absolute basics!
