M54A2 Brake Question
20,713
I'm not sure if this question has been asked before or not but, I'm looking to convert the single circuit system to a dual circuit. Would it be a bad idea to use an M35A3 master cylinder and a short airpack from it for the front wheels?
The only real issue is that you are going to need a single source of fluid. Could be from two different reservoirs - but you can't have a pair of master cylinders without a pair of brake peddles.
The M35a3 cylinder should work and it has two "outs".
One to the front set of brakes and a Second to the rear.
ThatMidwest5Ton
15
Stillwater, MN, US
The M35a3 cylinder should work and it has to "outs".
I probably should have worded it a little better but yes I'd be doing a complete master cylinder swap and using the existing lines, the only exception being what it would take to pipe in the second airpack for the front brake system. I just wanted to know if anyone advised against the use of the m35a3 master cylinder over finding an aftermarket for a heavier truck.
20,713
Got it... And I also updated my post from "to" to "two" outs. (Duh!)
I am of the opinion that the M54 weighs in at about 20,000 pounds. If you were to full load a bed full of heavy stuff I might be concerned - but otherwise it will be just fine with a deuce airpack.
ThatMidwest5Ton
15
Stillwater, MN, US
I forgot to mention that I will retain the 5 ton air pack for the rear brakes and trailer brakes. Based on how you're taking it I'd assume I should be fine with a m35 airpack specifically for the front wheels and the original for the rears. I'll likely do a writeup on how I'll be converting mine since it will be retaining 90% of the original system
Superthermal
1,037
Utah, Murray, United States
I had considered going to a Hydromax system to get away from air for the main brakes and to install a well built pinion brake for extra safety. I'm interested in what you come up with as keeping the air brakes for the trailer is a great bonus. I have in a box a steering column air brake actuator that is typically used to kick the trailer brake air ON without the truck's brakes that I had thought I would install if I did hydromax as I don't even own a trailer at this point.
ThatMidwest5Ton
15
Stillwater, MN, US
As long as you don't mind waiting until spring I can surely make a writeup for everyone here. Honestly shouldn't be terribly difficult as it's simply adding complexity and basing it off of the m35a3 system
Wreckclues
691
Jefferson, Massachusetts
I posed your question to the Grok AI on X here's the response...it draws on previous posts from Steel Soldiers.
Adding a dual circuit air over hydraulic brake system to an M809 series military 5-ton truck involves significant modifications to the existing brake system. Here's how you might approach this conversion:
Planning and Preparation:
  1. Research and Design:
    • Study the existing air-over-hydraulic system on the M809. Understand that this system uses air to assist hydraulic brakes but operates on a single circuit.
    • Decide on the dual circuit setup: You'll want two independent circuits, one for the front brakes and one for the rear, to increase safety by allowing braking even if one circuit fails.
  2. Component Selection:
    • Dual Circuit Master Cylinder: Choose one that can supply fluid to two independent systems. This might not be directly available for military vehicles, so look at similar systems in commercial heavy-duty trucks or adapt from other military truck series like the M939, which has full air brakes.
    • Air Brake Chambers: You'll need to add or replace the existing air packs with dual-circuit compatible chambers if you're retaining the hydraulic part of the brakes.
    • Valves: You'll need a dual-circuit air valve for the brake pedal. This could be a treadle valve from a commercial truck setup.
    • Air Tanks: Two air tanks, one for each circuit, to maintain air pressure independently.
    • Lines and Fittings: High-quality DOT-approved air lines and fittings for the new circuit.
Steps for Conversion:
  1. Remove Existing Components:
    • Remove the existing single-circuit master cylinder and the air pack if it's not compatible with your new setup.
  2. Install New Master Cylinder:
    • Mount the dual-circuit master cylinder. This might require fabricating a new bracket or modifying the existing one. Some have used parts from the M35A3 or M939 for this purpose.
  3. Air System Modifications:
    • Install the dual-circuit air valve where the brake pedal would actuate. This valve should control air flow to both circuits independently.
    • Install two air tanks if not already present, ensuring each circuit has its own air supply.
  4. Hydraulic System Setup:
    • If you're keeping hydraulic actuation for the brakes, connect the new master cylinder's outputs to the hydraulic lines going to the front and rear brakes separately. This might require splitting the existing hydraulic line into two.
  5. Brake Chambers:
    • If you're adding or replacing brake chambers, ensure they match the axle setup of the M809. The chambers should be dual-circuit capable, meaning they can operate on one circuit if the other fails.
  6. Air Line Routing:
    • Route air lines from the tanks through the necessary valves to each brake chamber. Ensure each circuit's lines are separated to maintain independence.
  7. Bleeding and Testing:
    • Bleed both the air and hydraulic systems to remove any air pockets, which could impair braking efficiency.
    • Test the brakes thoroughly, checking for pressure loss, proper application, and emergency braking with one circuit disabled.
Considerations:
  • Safety: Ensure the system meets safety standards, particularly for emergency braking. The dual circuit should allow for partial braking if one circuit fails.
  • Regulations: Check local laws regarding vehicle modifications, especially for military surplus vehicles intended for civilian use.
  • Maintenance: Dual circuit systems can be more complex to maintain, requiring attention to both air and hydraulic components.
Resources:
  • Discussions on forums like SteelSoldiers offer insights into similar modifications, including part numbers and practical advice from those who've done it before.
This is a complex modification that should ideally be undertaken with a clear understanding of both air and hydraulic brake systems or with the help of professionals experienced in heavy vehicle brake conversions.
ThatMidwest5Ton
15
Stillwater, MN, US
  5. Brake Chambers:
Considerations:
Resources:
I would love to convert over to air brakes but I don't have the spare 5k to blow on them at this time. As it would only cost me about 1k to split the systems
500 for m35a3 brake system(without lines to wheels and wheel cylinders)
240 for m35 airpack rebuild kit x2
200 for airdryer kit
60 for brake fluid
Besides, my initial question was really just wondering if the master cylinder from the m35a3 would work for the m54a2 brake systems, I have experience working with a milultitude of different braking systems, I just am not extremely well versed in the milspec hydro brakes. I just purely want the brakes to be slightly safer than their stock configuration
