5kw generator on a small humvee trailer, my house emergency backup powerLooks REAL good, Brother!
What's that trailer off to the side in the first pic?
Which paint did you use? It looks great!I can’t remember if i shared my paint job for the 1123 here or not, but here she was. Pressure washed with purple power, any rust spots neutralized, sprayed using my MTVR as a dry clean air source, and shot through a harbor freight $20 gun. View attachment 888703
Genius!Just a recap, but I used a cheap HF HVLP gun that I opened up with a 5/64" drill bit so that I could shoot the paint unthinned.
Funny how it's not 255 degrees or 257 degrees, but 256 Degrees.Has anyone painted an engine block with Behr Marquee? These LDT’s run pretty cool. Wondering if it would hold up. Latex starts to degrade at 256 degrees F.
It sure DOES look good!Painted mine with Behr 6 years ago and still looks good. The truck sat outside for most of that time also. I’ve painted 3 with it, and all turned out very well.View attachment 934486
Yes, I painted a deuce once that was a full inside and out job. The heat didn't affect it as much as fluid seepage which got under the paint. With the fan constantly blowing and the block surface hot it eventually peeled. Nature of the beast.Has anyone painted an engine block with Behr Marquee? These LDT’s run pretty cool. Wondering if it would hold up. Latex starts to degrade at 256 degrees F.
I power wash it in spring and late summer, damp cloth frequently for parades and shows. I use a semi gloss which helps too!It sure DOES look good!
How often do you wash that sucker down?
I've painted a couple vehicles - 5 tons and CUCVs.Great info here. Glad to see there's at least ONE project that will be "cheap" on my HMMWV. After several pages of reading within a 61pg thread....... what's the best way to prep before painting with the Behr? I'm assuming you can paint right over top of the existing CARC (i.e., no primer needed) as long as proper prep has been done, yeah?
While you can sand it, you don't necessarily have to. It really just depends on the truck. I've done some where the paint was pristine, but faded and others where it's clear there wasn't much prep work before even the CARC was put down. The CARC is a great base layer to paint over. if it's adhering good. The key thing is clean, clean, clean and when you think you're done, clean it again. I pressure wash to knock as much dirt off of it as I can. It's everywhere on these things. I'm a big believer in Purple Power for degreasing as well. Knock off any peeling paint, sand those areas if you'd like just to knock any hard edges, etc.Great info here. Glad to see there's at least ONE project that will be "cheap" on my HMMWV. After several pages of reading within a 61pg thread....... what's the best way to prep before painting with the Behr? I'm assuming you can paint right over top of the existing CARC (i.e., no primer needed) as long as proper prep has been done, yeah?
Ok, gotcha. That's more or less what I had in mind. Considered the grease trick too as that's what we used to do with R/C race cars but hadn't tried that one full scale yet. Good info.I've painted a couple vehicles - 5 tons and CUCVs.
I just took a 240 grit orbital and did a once over. I use grease or oil on the windows, mirrors, lights, etc. and go to town.
Only place I ever had any peeling paint was on the door sill where I stepped on it 10x a day, and on my M1031 where I didn't degrease the fuel fill area and it flaked off in about 2-3 years in a small almost unnoticeable area.
