- 1,017
- 1,864
- Colorado
I thought there was a special adjustment screw under the frame or somewhere that maybe adjusted that. I looked around, couldn't find anythingMaybe some weatherstripping to push the lid up higher? They are all like that BTW. Shitty design.
Yeah I was thinking that also but it's not easy to remove. You could likely bend it without removing it.Remove it, bend it, reinstall?
You can make it clamp tight.
Yes, I would suggest the same thing.They bend easily while still in the truck. Put a dowel or something underneath the latch and just push it towards the clamping area and that will cause a bend in the middle and enable it to be tightened up.
You can also just bend it with hand strength, they're pretty spindly.
Ok guysYes, I would suggest the same thing.
Place a dowel or bar against the latch body and push the latch spring plate up against it to bend it. If you open the battery box cover first, you might be able to bend it farther. I don't know how many times you can get away with bending it before it weakens it, as it may have been bent back some unknown number of times before, but you might give it a try.
That won't strengthen it. Those things are made out of mild steel.Ok guys. I'll bend it. I might heat it after bending to hopefully strengthen it. This latch is much like the stair banister ball in "Its a Wonderful Life"
I would think that part of the latch would be (or at least should have been) made out of some variety of spring-steel, but I don't own one that I can play with, and if it bends that easily in your experience, you could very well be right, although IMO if they used mild steel for that part of the latch, I'd call it a design flaw.That won't strengthen it. Those things are made out of mild steel.
No. Not a design flaw. "Lowest Bidder" is the answer to your question.I would think that part of the latch would be (or at least should have been) made out of some variety of spring-steel, but I don't own one that I can play with, and if it bends that easily in your experience, you could very well be right, although IMO if they used mild steel for that part of the latch, I'd call it a design flaw.
I don't doubt what you say!No. Not a design flaw. "Lowest Bidder" is the answer to your question.
Yeah but they never cared enough to redesign it.... 1993 to 2021 are all the same damn loose fitting latch. It's willful at this point when it's not been addressed for 28 years.I don't doubt what you say!
Of course, the net result of accepting the lowest bid can sometimes be a design or manufacturing flaw, depending on whether the bid was from a design firm that submitted a defective spec/design or from a manufacturer that didn't correctly follow the spec.
