WTK Thread and bolt size for front shackle
Guyfang
27,350
Burgkunstadt, Germany
For the bolt.
THREAD CLASS2A
THREAD DIRECTIONRIGHT-HAND
THREAD LENGTH1 INCHES MINIMUM AND 1 3/4 INCHES MAXIMUM
FASTENER LENGTH5 1/2 INCHES NOMINAL
HEAD STYLEHEXAGON
HEAD HEIGHT0 189/500 INCHES MINIMUM AND 403/1000 INCHES MAXIMUM
WIDTH BETWEEN FLATS0 461/500 INCHES MINIMUM AND 937/1000 INCHES MAXIMUM
SHANK UNTHREADED HOLE DIAMETER0 7/50 INCHES NOMINAL FIRST HOLE
NOMINAL THREAD DIAMETER0 5/8 INCHES
THREAD QUANTITY PER INCH18
DISTANCE FROM HEAD LARGEST BEARING SURFACE TO SHANK HOLE CENTER5 1/25 INCHES NOMINAL FIRST HOLE
COLORBLACK OVERALL
MATERIALSTEEL OVERALL
MATERIAL DOCUMENT AND CLASSIFICATSAE J429 GR 8 ASSN STD ALL MATERIAL RESPONSES OVERALL
PROPRIETARY CHARACTERISTICSPACS
SURFACE TREATMENTCADMIUM OVERALL AND CHROMATE OVERALL
SURFACE TREATMENT DOCUMENT AND CLASSIFICATIONQQ-P-416 TY 2 CL 2 FED SPEC SINGLE TREATMENT RESPONSE OVERALL
THREAD SERIES DESIGNATORUNF
jlt1987
Wappingers Falls NY
For the bolt.
THREAD CLASS2A
HEAD STYLEHEXAGON
COLORBLACK OVERALL
Thank you. Who sells the parts manual .
Guyfang
27,350
Try looking in the TM forum. Its there and free.
Mogman
10,594
Papalote, TX
You really should download the TMs that are here for free and study them, then you would know what the correct name of each part is and much more importantly the part number, then you just plug the part number into your favorite search engine and take you pick from the available vendors that have that part.
Reading the -10 operators manual is also a VERY good idea as these trucks operate differently than any civy vehicle and that will save you money by not making the mistakes that most new owner commonly make.
jlt1987
Wappingers Falls NY
Will do. Thanks. Charlie
spankybear
981
WA
Not that anybody asked but I really like to get my fasteners from McMaster Carr. One of if not the best company I have ever worked with!
