Zeus51
- 48
- 28
- Birmingham, AL
I agree with all of the above. There was a small change since plugging in the cluster.Ok. For my edification, key on, engine running, service light switch in the up position, headlight switch pushed in. Turn signals and brake lights should be functional.
headlight switch pulled out to first position, all marker lights, turn signals and brakes lights should be functional.
headlight switch pulled out to second position, headlights, all marker lights, turns signals, and brake lights should function
Service light switch in the up position + headlight switch off : no turn signals or brake lights
Service light switch in the up position + headlight switch ON : constant brake lights, and when I turn on left turn signal it shows that the left indicators on cluster, side markers and rear are all ON constant. Zero flashing. Same for using the right turn signal
I still need to check the rear grounds and clean the turn signal switch. Also wondering if I got a bad turn signal flasher? Could that be causing this?
I don’t have blackout lights attached. Do I need those to complete a circuit?
