- 3,144
- 4,727
- Olympia/WA
You are correct that it is no longer available as an AM General OEM part, but that doesn't mean it isn't being made by the OEM vendors
HPG has one from an original OEM Vendor in stock and explains the reason:
EFFECTIVE 10-2021 ANYTHING BUT "REM MFG" IS AFTERMARKET AND IS WORTHLESS POS AND DOES NOT OPEN OR CLOSE AT THE CORRECT TEMPS. AM GENERAL OBSOLETED THE SENDER IN 2015 AND STOPPED PROPERLY SOURCING IT WHEN THE HUMVEE WENT TO THE GEARED FAN DRIVE FOR COOLING..TLDR...SO EVEN THE AMG SOURCED ONES ARE INCORRECT - THEY DO NOT SOURCE FROM REM DO NOT TRUST EVEN AMG SUPPLIED SENDING UNITS - WE TESTED THEM AND THEY FAILED TOO. ONLY THE "REM BRANDED" ONES OPEN AND CLOSE AT THE PROPER TEMPS. IF YOUR SWITCH SEEMS TOO GOOD TO BE TRUE WITH PRICING,,DING DING DING, GUESS WHAT IT SUCKS. CHECK THE CAGE CODE, IT HAS TO SAY REM CAGE 045F6.
MacMotors also stocks the same switch
