Injection pump compatibility
Computerdoc08
219
Florida
Greetings,
I checked my parts manual and it doesn’t show compatibility, but want to ask the group here.
Is the LDS-465-2 injection pump 11641907 or LDS-465-1A 10951115 compatible with the LDT-465?
If compatible I assume I would turn down the fuel and verify EGTs?
thanks!
  • Like
Reactions: HDN
biscuitwhistler37
1,211
Michigan
LDS pumps are minutely advanced if memory serves, so I believe you'd turn the fuel up, but yes it will work.
Edit: just to confirm, your LDT is turbocharged, correct?
Floridianson
2,521
Interlachen Fl.
Oh, you would grab a set of LDS rocker arms and turn the fuel up! ** evil grin**
Yes, the LDS pump works just fine on an LDT. But...rocker arms and enjoy 200+ hp!
Sent from my SM-G991W using Tapatalk
I think that 200 horsepower is a little unrealistic from just a rocker arm change. One of the reasons the LDS had to be spun at 2900 RPM to produce the higher HP.
cattlerepairman
3,475
NORTH (Canada)
I was thinking that using LDS INTAKE rocker arms and an LDS pump should up the hp of the LDT to at least close to where the LDS sits. Maybe 200 is optimistic, but I am sure it would scoot!
Floridianson
2,521
Interlachen Fl.
Well a lot of people are happy with an FDC bypass and a good tune a pyro on an ldt they're happy with the way they run. You can turn the fuel up on an LDT and it will outrun a stock LDS pump but the problem will be the heat. Also it seems like a lot of people don't even want to spin it up to 2600 in fear of ventilating. While a complete LDS setup is going to run better you have to ask yourself is it worth the cost trying to make a race car out of a lead sled.
Floridianson
2,521
Interlachen Fl.
I'm only interested in and LDS injection pump as I can pickup a few for a really good price locally, but don’t want to buy them if I can use them. I won’t be tuning mine for extra HP, just a cheap replacement IP.
Sounds like a good plan. Sounds like you got the pyro covered the only thing I would add was get a new oil feed line to replace the old one when you exchange IP's
Davidwyby
244
CA
Well a lot of people are happy with an FDC bypass and a good tune a pyro on an ldt they're happy with the way they run. You can turn the fuel up on an LDT and it will outrun an LDS pump but the problem will be the heat. Also it seems like a lot of people don't even want to spin it up to 2600 in fear of ventilating. While a complete LDS setup is going to run better you have to ask yourself is it worth the cost trying to make a race car out of a lead sled.
Hi everyone (sorry for being away so long, eek)
Did the LDS have anything special in the bottom end to deal with the RPM?
Thanks
biscuitwhistler37
1,211
Michigan
Hi everyone
Thanks
Nope, same crank, pretty sure same cam, different rocker arms, and better designed pistons for cooling. To turn an LDT into an LDS, one simply needs an LDS rebuild kit and injection pump because the timing is just a little bit different. I think even the flywheel and clutch assemblies are the same, not certain though.
By far the easiest way to add 40-70 horsepower.
Floridianson
2,521
Interlachen Fl.
Thanks
Talking about RPM the first LDS that had a governed speed of 2800 RPM then the other models they dropped into 2600 rpm @ rated horsepower. No matter what, you want more horsepower build a hotter fire but have to deal with the heat The design of the multi-fuel engine we're working with is poor with no intercooler and heated intake manifold.
Davidwyby
244
CA
The pistons are surely very heavy. Throwing them up real fast and yanking them back down is probably hard on the poor rods. Perhaps it is more effective to just push them down slower and harder.
