Fuel drain for MEP 803A
jaybird67k
27
Texas
Looking for an original fuel petcock drain assembly. I took the OEM one out that wasn't leaking and put in the "upgraded" version and it leaks.
Any help would be greatly appreciated.
Thanks, Jason
2Pbfeet
1,296
Mt. Hamilton, CA
Are you looking for this item?
If so, I can confirm that the ones I purchased came with viton o-rings. Note: these are the bulkhead fittings with flats on the threads for a wrench to make installation easy.
All the best,
2Pbfeet
Light in the Dark
6,655
MA
Thanks, Jason
So you are looking for the brass drain, or the well nut? There are a number of low end copies of the 'ultimate well nut' that are on the market, that should be considered poor replacements. As 2Pb calls out, the right one has an O ring groove in the rear face of the bung assembly, and includes a correct Viton gasket.
The drain should be carried over and should work OK in the ultimate well nut, unless its been OVER tightened. That can/will cause the proper one, to leak.
Can you share which one you installed?
jaybird67k
27
Texas
The OEM one didn't have a o ring it worked by internal expansion. The one I purchase from a member on here that has a eBay store is a o ring style.
This is what was in it.
This is what I purchased that leaks.
2Pbfeet
1,296
Mt. Hamilton, CA
The original style rubber expansion well nuts have had issues for many folks. The replacement model bulkhead fitting that I posted above has worked for me. As it is brass and viton, it should be relatively unaffected by diesel and oxidation.
In principle, the solid brass fittings should seal better than the expansion versions, but both will be affected to varying degrees if the hole in the wall or interior surface are not clean or flat. The ones that callmecolt sells should work, but I have no experience with them. I prefer the ones from vendors such as Rotomold/Farmer Bob's and others, because of the flats on the threads make it very simple to tighten the bulkhead fitting to a reasonable torque from the outside. The best ones have a groove to retain the o-ring. I believe the McMaster-Carr versions have the groove, but it has been a while since I bought them from McMaster-Carr.
With the strainer removed, it is a five minute operation or so, with a 24-36" piece of wire, and a string attached to the wire. (Remove the old fitting, push a wire through the hole to the filler, put the bulkhead and o-ring fitting on the wire, bend a small "L" or "U" in the wire away from the bulkhead threads, and tie a string to the "U", pull the wire and the fitting into the hole, thread the retaining nut on, use the string to pull the wire out of the tank, and then tighten the nut to the bulkhead fitting. Done.) I think that the exterior flats make tightening the fitting simple and easy.
All the best,
2Pbfeet
Light in the Dark
6,655
MA
I think the O ring groove is key to sealing, which is why I would recommend the original 'ultimate well nut' upgrade. With the O ring in the groove, the sealing gasket is much more prone to properly sealing (where the ungrooved item, the gasket can distort for the reasons mentioned above. Plus the actual shoulder of the well nut is round (same profile as the Viton gasket), so its just a better part to me.
FarmingSmallKubota
1,316
Wapakoneta, Ohio
All the best,
2Pbfeet
I use this part on all the MEP 531a's that I sell. Replaces the well nut on the fuel drain just like in the 802/803 they work well, but always need to remove burrs and prep the surface
Lets make this easy here is a link to the discussion about the well nut
jaybird67k
27
Texas
The problem with the new style on my tank is the hole placement in the tank. They missed the mark and it's on the part of the tank where it begins to curve at the bottom. So the o ring is having a problem sealing so I want to go back to the old expansion type that was sealing in the first place. I don't think it's a part problem as much as the hole in the tank isn't flat. I can find the rubber expansion piece but not the screw that goes in it.
I wish I would not have threw the old one away.
Thanks, Jason
Light in the Dark
6,655
MA
And I think I have a valve assembly off a skid of an 802 (think its the same as the tank drain on the 803, I will reconsult the TMs)
CallMeColt
1,672
Wilson County, Texas
You got it from me it seems. I know the issue you're talking about & mention it in the item description as I have run into it myself on the installations.
I recently ordered a whole bunch of things from various distributors to try and solve the issue of tanks and the holes not linking up well with the body of the generators. Even with the superior fitting mentioned above, unless you remove the tank, the large brass nut will not seat right & it will never seal right & leak.
I found ONE vendor with a quality fitting that has the same hole size, yet the hex hardware is much smaller.... nearly 50%! This will solve the issue of fitment & alignment with installs & not removing the tank, as well as not needing to make holes in the body bigger.
This will help me stand out for the recent flood of China seller copies of my listings as well.
Also, I wanted to address the issue of the o-ring buldge & overtightening. My goal was to keep the cost down & still have a good, better solution. As well as have a "thick" enough sealing solution to makup for deformed tank walls where the original fitting needed to be yanked out. I have only had a few people complain about it as most people tacking a project like this understand to just tighten it enough not to leak, then slightly more.... like the original fitting. While not the best, once set, it will never leak again. When I started getting the brass bulkhead fittings from the distributor, they did have a bit of a lip to hold the o-ring. I noticed on my last order they don't anymore... that doesn't help.
To address this issue of the o-ring blowing out & still feeling like a tank with deformed walls can be sealed, part of my test order is a bunch of new, viton sealing solutions. One I found that I'm very interested in is one that is stainless & when pressure is applied, is "squeezes" the sealing rubber out to fill all the gaps. So you can CRANK on it as tight as you want! Other solutions coming as well to try.
The "ultimate well nut" solution is still great. The issue has always been stock & shipping. The manufacturer of it drop ships and it ALWAYS cost as much as the nut itself. Most people will get two. So the cost ends up being fairly high, IF you find them. Though, what isn't expensive now.
I've tried multiple times to get the manufacture to respond to me so I, with my business, can bulk order from them. They won't for some reason. If I could buy 1,000 at a time or something and make them a good cost... or at least the same but at least be a reliable, constant source for everyone, I would! But for some reason, they don't seem interested. I'm going to try again though.
Anyways, after all that said, OP, if you haven't already buttoned up, I will send you one of these new, smaller nuts at no cost to be one of the first to try if you want. Supplies may still be a week out to my door. Reply to me directly or via your eBay purchase, or a Direct Message to get it figured out.
CallMeColt
1,672
It's the same fitting, just the brass draincock threads directly in on the MEP 803A vs a NPT to AN-4 that goes to the hose. Why they just didn't make it the same, coming out the side of the frame..... military! Same as the top fitting on the tank as well.
LuckeyD
108
Vilseck, Germany
See OEM parts below. Page 2 line 50 left side. The comments so far have provided a metal tank drain plug. That puppy should work great. We used to see brass caps on the actual valve as they start to leak from dirt. Let us know what happens
