2Pbfeet
- 1,334
- 93
- Mt. Hamilton, CA
That would qualify as a good smokescreen generator in my book. That seems like a lot of unburnt fuel, and/or low compression.Video after new valve seals:
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
Any chance that the decompression lever could be slightly interfering with the valve? (The lack of wear on the rocker arm suggests that it is ok, but it is an easy check. There should be some play in the lever before it contacts the rocker arm.) I believe that using the decompression lever is not a great way to stop this engine.
If it were me, I would start by getting the fuel leak at the pump sorted out. The Yanmar engines are (rightfully) rather intolerant of anything that alters the pressure in the injection line- air leak into the suction side of the pump, and on the pressure side, fuel loss, a damaged flare, dirt/ debris on a flare fitting , plus of course a bad injector. In my experience even a tiny weep on an intake line is more than enough to overfuel the engine and cause issues.
I would double check that the pin of the pump is in the yoke of the governor.
FWIW: I keep a stock of new/known good injectors and pumps for these engines on hand. I find that it speeds up my troubleshooting.
All the best,
2Pbfeet
