Stock Trans Oil Cooling Lines Routing
WWRD99
1,940
York Pa
Does anybody know the correct routing for TH400 stock oil cooling lines?
They come off the block and go right to the crossover pipes to the radiator. Confused as to what needs routed? Are you missing parts trying to figure out what you need?
royalflush55
554
Reydon, OK
I think the original post is referring to the steel transmission oil cooler lines from the automatic transmission to the radiator. They get pretty messed up sometimes.
Sharecropper
1,261
Paris KY
Is there a part number for a line kit. Both lines?
If you need these 41-year-old lines your best bet will be to source them from one of the spare parts vendors. To my knowledge they are not available from GM already bent to shape. I feel sure John at Hillbilly Wizard can provide these in good serviceable used condition. Do you not already have these? I can't recall an occasion when the lines were missing or damaged. Hope this helps.
Sharecropper
1,261
Paris KY
These seem to be good.
I have a set going into my M1010 rebuild.
Inline Tube Transmission lines
Thanks Karl for posting that. I'm going to order a set on Tuesday simply because mine are all crudded-up and I don't want to take the time to de-crud them.
Edit: Just now ordered online and was pleasantly surprised to see they are offering a 15% Memorial Day Sale! Glad I didn't wait until Tuesday.
