M1151 Right Rear Sponson shoulder pin mounting bracket or striker
Davetheplumber
"Moose"
58
24
Corbett, OR
Can't figure out what it's even called but this is the part I need. I broke the one on the passenger sponson. Please, any help would be appreciated.
It holds the sholder pin for the slant back hatch to pivot on. Just above the passenger rear seat.
Davetheplumber
"Moose"
58
24
Corbett, OR
I guess ill try to fab something. I'm I doing something wrong on here? Not one response, idea or thought.. If I'm doing something offensive or not correct, please let me know.
flyfishtrailer
1,100
Cool, CA
It would be helpful if we knew what year and type of vehicle this part is used on. So maybe retitle it with the vehicle info so the experts for that vehicle type can chime in. The parts wanted does not fall into a vehicle category
Retiredwarhorses
4,557
Brentwood, Calif
This is a common part that fails on the sponsons, the replacements vary from aluminum to steel, here are the part numbers for each.
RH 13013793
LH 13013789
check eBay, as I’ve seen them listed at times,
Davetheplumber
"Moose"
58
24
Corbett, OR
You are amazing! thank you very much.. not the cheapest part on the truck but its been ordered. Thank you again. All off you on here... great community!
RH 13013793
LH 13013789
