Primussucks
- 73
- 18
- Dallas'ish, TX, USA
Weird. Magnet wouldn’t stick to mine.Neither… mine is mild steel…
magnet sticks to mine, 98 A0 With my filter relocation above the cab, I was contemplating fabbing a new one out of aluminum from turbo boot back to the duct that will run up the front wall of the habitat to the new filter location.Weird. Magnet wouldn’t stick to mine.
If you affix the new air filter to the habitat, what happens when the habitat and chassis go in different directions, because of chassis flex? Flex tube somewhere in air inlet tube length?magnet sticks to mine, 98 A0 With my filter relocation above the cab, I was contemplating fabbing a new one out of aluminum from turbo boot back to the duct that will run up the front wall of the habitat to the new filter location.
It's just a filter. Not that glorious or complicated. As I pointed out with the airflow - it's SIMPLY a matter of maintenance. Maintenance cost, maintenance interval, and maintenance ease.I'm curious, for the folks that are working on or have a camper build, what on your opinions on the stack mounted vs the barrel style air intake? I'm trying to get as much space possible for the habitat and was curious on the forum's opinion. thoughts?
General I would love to see a photograph of your rig. Do you, have you, will you share?It's just a filter. Not that glorious or complicated. As I pointed out with the airflow - it's SIMPLY a matter of maintenance. Maintenance cost, maintenance interval, and maintenance ease.
Those are all pretty easy things to visualize in your mind. Consider every option from each of those angles and pick which one meets YOUR needs. It will likely work just fine because pretty much anything will work fine as long as it's not annoying to access or requires frequent attention.
Sure.... But there's not much to see without looking really close because it's a 2008 M1079 A1R that I keep looking almost like it could have driven out of the Motorpool yesterday if you weren't intimately familiar with the van window sizes and that these were not equipped with awnings.General I would love to see a photograph of your rig. Do you, have you, will you share?
Sounds a lot better than a 1949-1970 Cadillac—Sure.... But there's not much to see without looking really close because it's a 2008 M1079 A1R that I keep looking almost like it could have driven out of the Motorpool yesterday if you weren't intimately familiar with the van window sizes and that was these were not equipped with awnings.
Most of the "improvements" are hidden in the details like the HIMARS parts, the camera system, the AC, etc - all largely made from military components used across the entire range of FMTV chassis variants and other related military hardware. I'm working right now on a steering wheel upgrade for example - but I'm starting with an 18" IMMI wheel that was NOS surplus for an EOD variant of the Cougar MRAP......
All the other newer military stuff (largely from Oshkosh) use some variant of the VIP line from IMMI. The HEMTT actually uses almost the same wheel I'm adapting and those are extremely common. Our S&S wheel was inherited from the Steyr which didn't have power steering (in all cases anyway) and as such needed an excessively large diameter wheel. I really just wanted a new wheel that wasn't covered in someone's 20 year old skin cells and oils. And I got this $300 wheel NOS surplus for $64...... it's also a game for me - how much $ can I save with surplus and still get a better result than buying some commercial Chinese crap. The IMMI wheel is made in USA.Sounds a lot better than a 1949-1970 Cadillac—
Yes,, 22” of habitat space thats NOT hanging off the back end of the frameAgain, we must be looking at this all wrong. Is there a great advantage to relocating all that equipment?
We like your build, using the top rail to add your floor joists is quite beautiful, you extended the rails rearward, right? How far does your build hang off the back end? Perhaps we have been using a 5x9 trailer so long a 14' floor layout looks huge on our garage floor. We may not need as much space as others and balancing the weight on the axles sounds quite appealing, the rear is too light.Yes,, 22” of habitat space thats NOT hanging off the back end of the frame… is a bit of work, which is why you don’t compromise… remove it all and push the habitat all the way forward to the cab latch and make good use of those 22 hard won inches. Scrap the AOP and valve, I basically gave mine away and it still paid for the hand pump. Re-config the coolant expansion tank to another location, it doesn’t have to be there either… move the oil filler to the side of the engine and trans dipstick forward beside the engine. You will need a trans access hatch in the hab and perhaps a raised floor anyway incase it needs serviced so put the trans main filler back there, you can always top up using the dipstick tube… ABS can go down near the air dryer, , and relocate the air filter up on the front of the habitat above the cab, high enough to allow the cab to tilt… the cab arch means you will always have ~4.5” of space between cab and hab, plenty of room for an intake duct on the passenger side to connect filter to turbo…
I extended the top frame 18” using the front lift arch I removed from behind the cab. That is about in the middle of the exit angle of the box so the total length from end of original frame length to back habitat wall is 33.5”. I am forecasting ~35 degree exit angle from the face of the rear tires when all is said and done… We are putting the kitchen counter across the back which will have some of the exit angle within the cabinets, as well as the structural ribs to support the rear mounted spare tire…, so a box with 17.3’ outside length will have 14.3’ of floor length from inside front wall to face of kitchen cabinets…We like your build, using the top rail to add your floor joists is quite beautiful, you extended the rails rearward, right? How far does your build hang off the back end? Perhaps we have been using a 5x9 trailer so long a 14' floor layout looks huge on our garage floor. We may not need as much space as others and balancing the weight on the axles sounds quite appealing, the rear is too light.
It looks once again, I have gone off topic—
I'm not affixing to the cab... mine will be attached to the forward most cross member.If you affix the new air filter to the habitat, what happens when the habitat and chassis go in different directions, because of chassis flex? Flex tube somewhere in air inlet tube length?
I haven't got down to the air lift arch yet and haven't decided on the position of the filter. If the arch stays, then probably a structure that is welded to the arch or something around the coolant expansion tank.
I like the idea of affixing it to the habitat, but I don't know how to accommodate the chassis flex and habitat zero torsion setup
understood. My goal is to try to get as big of a habitat on the back as realistically possible. Since it’s M1085 it has a 20 foot bed and there’s 18 inches between the bed and the cab so if I could steal another foot there that gives me 21 feet for 2 feet to hang over the back. But if I can cover the air filter and the reservoir on the other side that may give me another 6 inches. Every little bit counts.It's just a filter. Not that glorious or complicated. As I pointed out with the airflow - it's SIMPLY a matter of maintenance. Maintenance cost, maintenance interval, and maintenance ease.
Great work! Love watching the progress on your truck.I'm not affixing to the cab... mine will be attached to the forward most cross member.
Bracket is mostly made.. just need to test fit the boxes again and make finished the bottom mounting.
Depends on the tune you are running. On the 370 HP map I have seen boost pressure around 33-34psi.Does anyone know what PSI the waste gate opens on the turbo?
