Fixing the 1998 HMMWV
mrandig
171
Houston, TX
Fan temperature switch replacement.
I wasn't necessarily having problems with my fan temperature switch, but while I'm in here anyways...
Visual inspection shows this switch has seen better days. It's a little odd that it's so far gone, but whatever.
I'm just using tape so I can see the connectors.
Removal requires a 7/8 wrench.
Righty tightey, lefty loosey.
Even the wires are bad on this one.
The wires are actually worse than I just thought.
A little scrape of the surface with my plastic razor blade, just to clean up.
Some thread sealant (with PTFE) on the new switch.
I can't read these tiny numbering tags. I'm assuming that, if this is a resistance switch, it shouldn't matter if the leads are reversed. I'll look into it further after this post.
Tighten accordingly. The TM-20 doesn't give a torque spec here, but I wouldn't go to hard. Remember this is a 7/8" wrench, so it's easy to over-do it. A cracked crossover would be a bad day.
For cleaning the electrical connections, I'm now using Deoxit D5. I ran out of my usual QD spray, so I'll need to hit the store soon.
Dielectric grease on the insides of the connectors. This looks like way more than it actually is.
I think we're done.
mrandig
171
Houston, TX
Lower radiator mount replacement.
As I'm replacing the radiator, I'm also going to replace the radiator mounts.
The lower radiator mount is shown in the picture. I'll do the two uppers when it comes time to put the radiator in.
At first, I started with a pry bar, but I began to feel like I was just trying too hard. Almost like taking a shotgun to go fishing.
Then I switched to a big screwdriver.
Finally, the mount came out when I used both together.
Here's the new mount ready to install.
A little dish soap for ease of installation.
Pops right in.
Done.
mrandig
171
Houston, TX
Coolant hose replacement.
Well, it looks like we're almost back to where we started. It's been one hell of a detour.
To be honest, one of the reasons I was waiting on paint was to do the lower tube. It almost looks too nice now.
We'll have to see how it holds up with use, cause that tube is going to get hot.
Because a lot of these connections can be fussy, and some even brittle, every hose gets some dish soap on the inside prior to installation.
As a general rule, all hose clamps less than 1/2" were torqued down to @15 in/lbs. Anything 1/2" and over was torqued down to 30 in/lbs.
Lower water pump hose installed.
Lower water tube installed.
Lower radiator hose installed.
Lower radiator hose routing.
Lower surge tank hose and clamps.
Lower surge tank hose installed at water tube.
Lower surge tank hose installed at surge tank.
In addition to the lower surge tank hose, there's also two upper hoses.
One of the upper hoses goes to the water crossover, the other goes to the top corner of the radiator.
These new hoses are silicone and are softer than rubber. The existing clamps were having problems tightening correctly, so they had to be redone.
All hoses are complete. At least until the radiator goes in, then they'll just need to be connected and tightened up.
Coug
4,755
Olympia/WA
So far so good - the paint is a great match. I feel like painting everything I can at the moment, but I won't.
I got mine from QTM Parts on ebay. I think the price is a little higher, but probably not even a dollar more. I haven't compared shipping costs, so that may make the difference. It did show up quickly.
Not sure if the newer paint cans suffer the same issue, but the older cans they used seemed to have issues if they sat for too long, even brand new. Purchasing directly from Rapco is the easiest way to get the freshest cans of paint.
mrandig
171
Houston, TX
Idler pulleys, water pump pulley, belt tensioner, and serpentine belt installation
For this post, I'm going to do the serpentine belt and all of its components, including pulleys and hardware.
First are the upper idler pulleys; there are two smaller ones.
Installed and torqued to 37 ft/lbs. (GM spec).
Next is the larger pulley. The long bolt will go into a bracket attached to the right cylinder head. Installed and torqued to 37 ft/lbs. also.
There's also a long spacer that the pulley will need to go through.
All three pulleys installed.
Next, we'll do the serpentine belt tensioner.
I'm torquing this tensioner to the same 37 ft/lbs.
The water pump pulley gets installed next.
There's a total of 8 holes. The inner 4 are for the water pump pulley, the outer 4 are for the fan.
The pulley will only fit one way, so you'll likely have to install the pulley and then spin the pump to align the holes.
Loctite comes next. I'm using blue 243, which is a general purpose threadlocker that provides a medium-strength bond. It can be removed with hand tools if there is ever a need.
Does everyone know Loctite expires? Of course, as soon as I noticed this, I immediately threw this bottle away and bought a fresh one;).
The water pump pulley bolts need to be torqued to 17 ft/lbs.; but there's no good way to do this, as the pulley will keep spinning. Once the belts installed, then it's easy.
Move the tensioner clockwise to allow installation of the serpentine belt.
Route the serpentine belt around the crankshaft pulley, under the two upper idler pulleys, around the alternator pulley, power steering pump pulley, water pump pulley, and tensioner pulley.
Release belt tensioner.
That's about it for the moment.
I'm going to wait until everything else is done before putting the fan and clutch back on. We'll do that when it's time to put the new radiator in.
mrandig
171
Houston, TX
Just a small project from yesterday. There's a lot of little details that need to be addressed.
Seat backs, or floor sections (I've got a two-man truck), with new pins and cables. Now, I don't have to worry about my floor sections smacking me in the back if I come to a stop too quickly.
I really need to hit these again with some compressed air, as I can still see sand in these pics.
mrandig
171
Houston, TX
Radiator replacement (1)
Time to get to work on replacing the radiator. Before doing so, you'll need to remove the transmission oil cooler and power steering cooler, if so equipped.
This is a picture from a week or two ago. My radiator has already been out for a while now.
The radiator has a lower mount, and two side mounts. Once unbolted, and all hoses removed, it can be manipulated out of the truck with a little patience. It is heavy, so you'll probably want an extra set of hands.
The shroud is held onto the radiator with 2 metal strips: one on each side, with 4 bolts each.
Once the retainer and bolts are removed, the shroud comes right off.
Wash with soap and water.
Don't wash while it's sitting on your tool cart however, or you'll get your phone and tools wet.
And then wash some more. It's plenty dirty.
This radiator isn't going back on. I've got an aluminum replacement, so I'm just moving it out of the way.
Damn it's heavy.
Here's the shroud almost clean.
Cleaner still...
Cleaner still...
And I just noticed - it's cracked.
D'oh.
From the looks of it, this shroud was cracked a long time ago and just cemented back together. I will need to come up with a plan tomorrow, but I've got no interest at this point in buying a new one. I've got a plastic welding kit...?
mrandig
171
Houston, TX
Fan shroud plastic repair (1)
Crack in fan shroud viewed from top.
Crack in fan shroud viewed from below.
The plastic welding kit is from HBF.
I've had this kit for years; I was wondering if I'd get to use it someday. I guess that day is today.
We'll use some fine stainless-steel mesh as reinforcement for the repair.
Once cut to size, the SS mesh is laid down over the crack.
Heat is used to warm the mesh and melt the plastic underneath.
Once melted, the mesh is pushed into the soft plastic, creating a reinforced repair. For this side of the repair, no additional filler material was required.
On the outside, we'll use a Dremel tool to clean up and open the crack.
This tip was a little small. I ended up using a larger tip on the Dremel tool, and everything was fine.
Ultimately, I ended up with a groove around 1/8" wide, going to down to almost the repair on the opposite side.
A heating rod is then used to melt plastic filler rod into the groove.
Here's the final welded repair. I don't think I'm going to try to even sand this flush. It looks fine and really isn't very noticeable.
mrandig
171
Houston, TX
Fan shroud plastic repair (2)
Just to wrap up this repair, after plastic welding the fan shroud was looking pretty rough. I had used a DA sander on the surface, and this left the plastic looking very dull.
I'm going to try some mirror glaze and see if we can get some shine back. This isn't because I want shiny, but rather to make the old and repaired parts of the shroud match as well as I can.
I'll try some fine-cut cleaner first. This is a medium abrasive (5/10).
I'll follow up with some swirl remover. This is a much finer abrasive and also serves as a polish (3/10).
Looking better, but there's still more to do, and I'm getting bored with this.
A 7" electronic polisher makes this go quickly. Actually, it goes so fast, care must be taken to avoid overheating the part. It is possible to melt the plastic using this tool, which would not be a good thing.
All done.
osteo16
598
Evansville, IN
put some 1000 grit on that , you worked to hard.
