Kinda got carried away..... M1028 rebuild
Sharecropper
1,227
Paris KY
After completing the installation of the Vintage Air system, I cleaned & undercoated the underneath of the cab. It didn't take much cleaning, as it still looked new from sitting in Arizona all its life. Still amazed at the absence of rust. Got the new drivetrain bolted in place over the weekend. Everything fit like it should, except I had to drill two new holes in the frame for the crossmember on the passenger side. Used all new Grade 8 bolts, washers & nuts. All engine mounts, including the frame mounts, were sandblasted, phosphate-treated, primed & painted with two coats of Rust-O-Leum semi-glass black. Also did the same for the crossmember and skid plate. Attached & adjusted the transfer case cable shifter, works wonderfully. Plugged-in the 4WD indicator switch and attached the speedometer cable. Verified that I had the correct blue 18-tooth drive gear in the NP241 and gray 44-tooth driven gear to correctly calibrate the speedometer with my 37-inch tires. Next I will begin to attach all wires & hoses to the new engine, in preparation of reinstalling the core support and new radiator. More updates coming.
Sharecropper
1,227
Paris KY
OK I have been asked about the PCV valve and how it will be hooked up, so here is my reply for all to see: Because the supercharger intake is at the rear of the blower, and because I mounted the centrifugal oil filter on the drivers side of the intake, the housing and in-line air filter for the supercharger had to come around the passenger side of the intake. Consequently, the CUCV PCV valve was right smack dab in the way. So to solve the issue, I sourced, on Ebay, a civilian 6.2 PCV bracket, which was engineered by GM to be located right over the passenger side alternator. However this only solved part of the problem, as the civilian bracket positioned the valve too high to be connected with the CUCV oil fill tube. I considered using a civilian oil fill tube, however that wouldn't work and still clear the supercharger snout. After thinking about the problem for a few days, I decided to simply cut the civilian bracket in half and shorten it so that the hose would connect to the CUCV oil fill tube at the proper elevation. Then I had to figure out how to connect the PCV valve to suction so that it would work correctly. The suction would need to be downstream from the air filter but upstream from the blower. I reached out to Tom Rabold, engineer at Bullet Racing in Australia, the designer of the supercharger intercooler intake for the 6.5 diesel. Tom shipped me a special brass elbow, and I drilled & tapped a corresponding hole in the underneath side of the rear blower housing. Bought the correct size hose from NAPA and hooked it all up. Worked like a dream. All this is shown in the photo below for anyone wanting to go down the same road as I have gone. Hope this helps yall to understand my red-neck engineering.
And before anybody asks, the white thing on the makeshift firewall is the 24v aircraft pre-oiler pump which will circulate oil to all bearing surfaces while the glow plugs are warming up. It sucks from the oil pan and pressurizes the galleys at the plug over the oil-cooler lines on the drivers side.
Sharecropper
1,227
Paris KY
Got the new all-aluminum radiator installed yesterday. Fit was excellent, however the overall height was approximately 3/8" shorter than the OEM radiator. I had some black neoprene rubber in the shop, so I fabricated a couple of saddle spacers to fit over the top mounting tabs which made the radiator support brackets fir correctly. Ran a SS self-drilling screw down through the brackets to hold everything in place.
Sharecropper
1,227
Paris KY
Pulled the core support back off and clamped it on my bench, then fit the new Derale #16843 dual electric fan to the radiator. This dual fan provides 4800 CFM cooling capacity, which will be helpful to pull fresh air through the intercooler for the supercharger, A/C condenser, and radiator. Also bought the Derale #16797 fan controller which features soft-start and variable speed which is determined by a sensor which is epoxied to the radiator tank. The controller adjusts the fan speed based on the temperature of the tank. The hotter the tank, the faster the fan speed with more air pulled through and vice-versa. During the fan install, had to make a few sizing adjustments, as well as to fabricate and install aluminum brackets which strengthens and attaches the entire radiator/fan assembly to the core support. Test-fit it and discovered that there was a 3-1/2" space between the fan shroud and the supercharger belt, so today I plan on pulling-off the core support and pulling out the entire drivetrain, and re-positioning the engine mounts to provide an additional one-inch clearance between the rear of the engine and firewall. This will also require drilling new holes in the frame to re-position the transmission cross-member. More updates coming.
Sharecropper
1,227
Paris KY
Today I got the drivetrain moved forward one-inch by repositioning the engine mounts on the frame platforms. Before removing the engine to do this, I marked the outline of the mounts on the platforms with a white marker, and then after the drivetrain was removed, I removed the bolts in the mounts and simply moved the mounts forward one inch, temporarily clamped them in place, drilled new holes and re-bolted the mounts in place. Set the drivetrain back in place and onto the repositioned mounts, and while my forklift gantry was still supporting the weight, I bolted the transmission crossmember to the adapter and then drilled new holes in the frame for the repositioned crossmember, while making sure it was centered between the frame rails. Used the existing holes in the crossmember as guides for my drill bit. Worked like a champ. This drivetrain repositioning provided more clearance between the rear of the supercharger and firewall, which is essential because the coolant lines from the intercooler enters & exits the manifold at the rear of the supercharger intake. The intercooler is a small radiator fit into the intake below the supercharger, see photo below. Now there's plenty of room for everything including the OEM wiring harness which runs behind the intake. Next I will begin to hook everything up. Starting to get exciting.
Sharecropper
1,227
Paris KY
Since my last post I've gotten a lot done. Powertrain is bolted in place; aircraft pre-oiler is mounted where the OEM fuel filter was on the firewall; 24vdc relays are mounted and wired back to the dash switches, as well as powered from the 24v buss on the firewall, the pre-oiler pulls 4 amps at 24v so I fused it with a 7.5 amp fuse. The other relay on the right of the photo is the 24v relay for the intercooler pump which will be mounted on the driver's side inner fender. That pump pulls 2.25 amps at 24v so I fused it with a 5 amp fuse. The custom gauge cluster is almost plumbed & wired, just need to hook-up the boost tube and run the EGT lead to the header extension. Next on the agenda is to order the new rear driveshaft from Shawn Woods. With his help, I determined that I needed to rotate the rear axle 6 degrees to be in spec. This was due to the earlier installation of the ORD Rear Shackle Flip kit. The way the Shackle Flip kit works is just how it sounds - it positions the rear shackle of the rear springs below the shackle hanger instead of above it, thereby providing 4 inches of lift at the axle. But in doing so, it also rotates the axle causing the U-joint to rotate upwards. The face of the Slip Yoke Eliminator on the rear of my custom NP241 is tilted at 6 degrees, and the angle of the future driveshaft will also be at 6 degrees, however the face of the U-joint was at 13 degrees, Shawn recommended installing 6 degree steel shims under the rear spring pack, which will cause the U-joint face to be at 7 degrees after shim installation, which will be almost perfectly aligned for a smooth-running driveshaft. Will post photos of all this when I get it done.
Sharecropper
1,227
Paris KY
How's the truck coming along?
Things are coming together nicely. Since my last post I have completed the modifications necessary to reinstall the OEM oil cooler lines. The original lines are clean and in great shape, having only 15,178 original miles. I had to modify the Derale fan shroud so that the OEM hard lines could run across the face of the new all-aluminum radiator in the same routing as originally designed by GM. I test-fit the header on the driver's side to make sure the oil line-to-engine connections cleared, and they did with room to spare. Also test-fit the header on the passenger side and discovered that I needed to shave the frame slightly in one spot to provide sufficient clearance for the rear cylinder down pipe. I got this done, primed & painted the little scoop-out. Then I discovered that the OEM transmission cooler hard lines could not be reinstalled due to the deeper oil pan and 3-inch girdle of the P400 engine. I considered fabricating new hard lines but finally decided to simply order flexible lines from Summit. These arrived and I got them routed and secured-in-place to suit me. Had to fabricate a couple brackets to secure the line clamps in place. The flexible lines are available in 5-foot or 7-foot lengths; I determined the 5-foot lengths would be too short, so I purchased the 7-foot lengths, which were slightly too long. To solve this issue I simply looped the lines at the transmission and secured them with a clamp on the frame. Worked out nice. The route of the transfer case-to engine brace went right through both lines where they connected to the 765R4 transmission, so I cushioned the stainless-steel braided lines and tied them off to the brace. The radiator ends of the lines simply attached to the radiator with 5/16" inverted flare / -4AN adapters which came with the new radiator. I then stabilized the oil cooler hard lines to the transmission cooler lines at the radiator with strong zip ties. After completing the transmission cooler line installation, I then had to complete the suction line for the aircraft pre-oiler pump. I had previously welded an aluminum bung in the thick cast aluminum engine oil pan for this purpose. I used -6AN hose from a swivel fitting at the pan, through a screen filter and then through a check valve and then completed the suction line to the pre-oiler pump mounted on the firewall. Everything so far has worked per plan. Next I need to install 6-degree shims at the rear axle to get the driveshaft angle corrected. Will post photos of that adventure soon.
Sharecropper
1,227
Paris KY
An update - after installing the flexible stainless-steel -braided transmission cooling lines, I came to the conclusion that I did not like them. The sharp bends had caused a few of the stainless-steel braiding wires which wrapped the lines to break, causing a few rips in the epidermal layers of the skin on my hands (even with gloves on!). The more I looked at those SS braided lines, and considering what I had to go through to get them installed, the more I disliked them. In addition, after thinking through how the GM engineers had used the hot side tank of the radiator for the transmission cooler (the engine oil cooler is inside the cooled-side tank of the radiator on the passenger side), I started considering a complete redesign for the cooling of the transmission fluid. The hot-tank-side of the radiator receives 180-210 degree coolant straight out of the engine, and then passes that hot coolant through the horizontal rows of vanes of the radiator to be cooled to end-up in the cooled-side tank for re-entry into the engine. This original design means that the only OEM cooling apparatus for the transmission fluid is inside 180-210 degree coolant! I decided to do something about this inefficient (my opinion) design flaw.
I removed the SS braided lines I had just purchased & installed and threw them in my dumpster. I then ordered & received a Derale #13225 frame-mounted cooler and mounted it inside the frame rail on the driver's side. I then fabricated custom Vibrant nylon braided lines (no SS!) from the ports on the Bowtie 765R4 to the radiator cooler, then to the frame-mounted cooler, and finally back to the transmission. Chris Gardner at Bowtie confirmed that the bottom port of the 765R4 was the hot pressure port and the top port was the suction for the cooled fluid. So I ran the hot fluid to the radiator first in red-themed nylon-braided -6AN hose, attaching to the bottom radiator port, and then from the top radiator port I ran blue-themed -6AN hose to the frame-mounted cooler, and from there back to the suction port on the 765R4, also in blue-themed -6AN hose. The Derale #13225 frame-mounted cooler is a 24" loop-type finned cooler, meaning the fluid passes through 48" of cooling fins before being returned to the transmission. Instead of routing the -6AN lines under the engine as was done in the OEM design, instead I ran both the pressure and return lines over the top of the transmission, thereby eliminating the possibility of a line becoming damaged when traversing rough terrain or due to a road hazard. I am now happy with this custom transmission cooling design.
I also got the ceramic-coated headers installed and all bolts torqued, and installed new AC Delco glow plugs. Anti-seize was used on all threads where thread locker not used. The pace is picking up. More updates coming soon.
Sharecropper
1,227
Paris KY
Beautiful work. Where in the world did you get those headers? Are they an old set of Stan's?
Thanks for the compliment. Yes those are Stan's. I was fortunate to obtain the last set of 6.5 headers from him in 2018 before he retired. To my knowledge there is no other current source for 6.5 headers short of a complete custom-fabricated purchase, which would probably be cost-prohibitive.
Sharecropper
1,227
Paris KY
Today I was finalizing small tasks around the engine compartment prior to re-installing the inner & outer fenders next week. I fabricated & installed an aluminum post bracket & clamp to hold the new accelerator cable away from the Spinner centrifugal oil filter, as well as to maintain the cable in the proper position to prevent strain where the cable attaches to the pump bracket. After installing the bracket and fastening the cable and looking to see if there was anything else to do on that side of the engine, it struck me what a great photo it would make to show some of the ancillary systems I have engineered into the new drivetrain. The photo shows 1)- the Bullet Supercharger, 2)- the red anodized AutoMeter Fuel Isolator mounted on the firewall over the center of the Supercharger, 3)- the Spinner Centrifugal Oil Filter and -6AN oil pressure supply hose, 4)- the aluminum post bracket & clamp holding the accelerator cable next to the Spinner, 5)- the aircraft pre-oiler pump mounted in the OEM fuel filter position, 6)- the AutoMeter analog thermocouple line running alongside the Supercharger to the front port of the HMMWV crossover pipe for the water temperature gauge, 7)- the drilled & tapped & plugged orifices in each intake manifold leg for the Snow Water/Methanol injection system, 8)- the egress hose coming out the rear of the intake for the intercooler coolant circuit, 9)- switch-operated 24v relays mounted on the firewall next to the pre-oiler pump to close the circuits for the pre-oiler and intercooler pumps, and finally 10)- the under-coating of the firewall which extends across the entire bottom surface of the cab. The cab bottom was clean and in new condition when I acquired the truck in 2010, so to protect the cab bottom I sprayed a liberal coat of GM undercoating on the entire bottom before the new drivetrain was installed. More updates coming next week after I get the fenders on.
CARC686
706
New Mexico
Please forgive my ignorance, but where is the intake ingress? It only crossed my mind because I was thinking of the scoop on top of "the last of the V8 interceptors" and I realized I see no air inlet whatsoever.
Sharecropper
1,227
Paris KY
The Supercharger intake is an aluminum casting that bolts to the rear of the blower and turns towards the fresh air opening in the core support on the passenger side. I'm using an inline air filter which attaches to the casting, and a flexible duct from the air filter to the fresh air opening. I've already had all this assembled to make sure it fit, which it did with no problem. But it takes up a lot of room on that side of the engine so I removed the components and placed them back in the boxes for safekeeping while I got everything else worked out. I'll post photos of the completed engine compartment after I get the fenders back on next week and the Hawker batteries installed. I also need to run the heater hoses and lines for the Vintage Air Conditioning on that side of the engine. The engine compartment will be full for sure. Here's a photo from Bullet in Australia which shows the casting. Not my engine.
Sharecropper
1,227
Paris KY
Today I'm working on the intercooler system for the Supercharger. I mounted a Hayden #1268 intercooler in the only place in the grille it could be mounted. The #1268 is the only intercooler I could find which incorporated 3/4" piping throughout to accommodate the 3/4" I.D. hoses from the intake. The #1268 has a cooling capacity of 31,200 BTU. This cooling capability, with the flow capacity of the intercooler pump of 9.77 gallons-per-minute, should remove most if not all of the heat from the charge air downstream of the Supercharger. The #1268 cross-tubes have turbulators which spin the coolant as it travels across the fins, thereby providing maximum heat exchange. I'll post more photos when I get a little further along.
Sharecropper
1,227
Paris KY
Now that I have the intercooler as far as I can take it until the inner fenders go back on, I have turned my attention to finishing up the minor things on the engine. I had to remove the supercharger in order to install the rear air inlet housing to the blower. The housing is attached to the blower with eight stainless steel Allen-head bolts, and there is just no way to access & install these bolts with the blower installed. With the blower out of the way, this first photo shows the heat exchanger inside the intake. You can see the Huckstorf custom-built DB5437 injector pump on the right and the coolant ingress/egress hoses on the left. The intercooler is an isolated loop system which runs at ambient pressure.
This next photo is a side view showing the rear air intake housing coming around the passenger side of the engine.
This next photo shows the PCV hose installed. It had to run from the civilian PCV valve at the front of the engine to a location upstream from the supercharger but downstream from the air filter. This involved drilling, tapping, and installing a brass fitting in the underside of the housing to accommodate the PCV hose.
This next photo shows the Spectre #9833 inline air filter attached to the rear air intake housing with Vibrant silicone adapter and clamps. After I get the inner & outer fenders installed and the Hawker batteries in place, and after running the engine coolant lines and Vintage Air refrigerant lines, I will then install the flexible air intake hose from the Spectre housing to the air inlet in the core support.
This last photo shows the completed supercharger system from the top. Note that I installed the intercooler reservoir on the driver's side of the blower.
Sharecropper
1,227
Paris KY
Decided to finish installing & plumbing the electric fuel pump. I used a Carter P4600HP which is a 12v, 50 gallon/hour 4.5-8 psi frame-mounted pump. I wanted to use a 24v but the P4603HD was nowhere to be found. The 12v model pulls 10 amps and will be ignition/relay-wired. Not knowing how much fuel the supercharged P400 will drink in WOT, I reached out to Bob Reynolds at Carter Technical Service for his opinion. Bob ran calculations for diesel fuel consumption in a 6.5 GM engine producing 300 HP and recommended the P4600HP. He indicated that the P4600HP might be slightly over-sized, but the fact that the fuel return line from the engine to the tank is a full 1/4" line, means that any excess fuel not needed by the engine will simply be returned to the tank. This is another reason why I incorporated a fuel pressure gauge in the custom gauge panel, so I can make sure the engine is not fuel-starved.
While I was under the truck and in the process of mounting the fuel pump to the frame, I decided to also incorporate a filter between the twin tank valve and the pump. After spending hours evaluating numerous diesel fuel filters online and at Summit, I chose a HENKYO R12T 10-micron, which is also a frame-mounted unit. The R12T also features a water separator with a clear bowl to catch any water incoming from station fuel. Both filter and water bowl are spin-on/off and the bowl has a handy threaded drain cock knob which can be operated with gloves on. In order to provide a straight-through route for the forthcoming 3" exhaust, I mounted the R12T on the cross-member under the front of the bed, between the exhaust route and the forthcoming new driveshaft route. New 3/8" rubber fuel line was used but I wanted to re-use the OEM hose clamps for nostalgic reasons. Mounting the P4600HP fuel pump on the frame caused a complication of hose routing, so I cut-off the 3/8" hard line from the engine just forward of the pump and installed a 3/8" compression x 3/8" hose barb adapter onto the hard line to connect the rubber hose. Everything worked perfectly. Before I crank the engine for the first time, I will disconnect the 4AN hose running to the fuel isolator on the firewall and energize the pump with a battery to pre-prime the system but also to run a quart or so through the filter & pump & lines to clear any small particles or debris left over from the manufacturing processes. More updates coming soon.
