- 352
- 319
- 63
- Woodside CA
For you folks with C7 powered trucks, I'm curious how much blow by you see out the breather. Thanks
Thanks, that's where my oil level is, but I was referring to gases coming out, not oil.Lots unless you run them two quarts low. It will spit out what it doesn't want. CAT redesigned the breather to be more like the 3126 to avoid it but it doesn't fit under our cab.
The military guys all know about it and just run them halfway between the low and full which is 2 quarts. That's also what I preach and practice personally.
Mine smokes a good bit out of the breather on cold starts if it has been sitting for a while. Not nearly as noticeable during warmer weather and if it is driven more frequently.For you folks with C7 powered trucks, I'm curious how much blow by you see out the breather. Thanks
Yes, I realized that when trying to attach it. Didn't really want to mess with that but did anyway. Even though it has been uploaded to youtube, when I try to insert the link it says I can't.You have to upload it someplace like Youtube and link to it…
Done. I thought since I shared it here, it would allow people accessing here to see it.You need to make your video public on YT…
Phone is the easiest way.I took a video of mine and the file was corrupted. Have to try again. Don't use my go-pro that often.
Cool, thanks. Looks just like mine.@GCecchetto here's mine after a cold start around 40°F: https://youtube.com/shorts/zbHlE_uyk-4?feature=share
On this Breather issue, can the existing breather tube be routed into a remote tank that's then outfitted with the proper cat breather? Should it be a stainless tank or just anything that will fit that tall Cat breather?Lots unless you run them two quarts low. It will spit out what it doesn't want. CAT redesigned the breather to be more like the 3126 to avoid it but it doesn't fit under our cab.
