Thinking about buying a 5 ton -- need advice please!
db72
42
13
Palmyra, MO
Good evening everyone. As I mentioned in my introduction post, I'm thinking about buying a 5 ton, and I want to make sure I have all of my bases covered.
I can already tell this post is going to be longer than some novels, so please bear with me.
First things first, I guess I should describe what I'm looking for. This all started one day a couple months ago when I was browsing FB Marketplace, and I saw a cool '61 GMC cabover that someone had put a ramp bed on to use as a car hauler. I was actually looking for a 67-72 Chevy Suburban at the time, and thought that having something like a ramp truck would be a great way to haul around various projects. The cabover was cool, but not really my style. I thought about getting a 67-72 Chevy C60 grain truck, removing the bedsides, and adding a small dovetail to be able to load things more easily. I didn't much care for the big block 366 gas that was in most of those trucks though, so I wanted to put a big diesel in it. I pretty quickly figured out that a Cat 3406B or Big Cam Cummins wouldn't fit without hacking out the firewall and having basically half of the engine in the cab with me (doghouse style). That would be a lot of work, and I wouldn't have it done in a reasonable timeframe. I started thinking about other options when I remembered the bobbed Deuce my uncle used to have, and how I've wanted a military vehicle for quite a while.
I found an M812 bridge truck that had the bridge bed removed, and I got to thinking. The M812 has a diesel already in it, and has the space in the engine bay if I decide to put a hotter motor in it in the future. The manual transmission is important to me too, which is why I haven't looked at the M939 series as much. I didn't want a Deuce since the weight capacity is less than I'd really like. The Deuce also wouldn't be a good platform for the larger diesels either, even though I'm sure something like a 5.9 or 8.3 Cummins would do what I need. What I'm looking for is something that I can cruise around in or let people ride on in parades, but also be capable of moving vehicles, tractors, equipment, etc. when I need a vehicle to do heavier work. With the M812, my thought was to see if I can find a flat bed for it that is about the right length to be flat to the end of the frame/right above the rear axle, then have a dovetail at the end so I don't need crazy long ramps. I'm not dead set on an M812 though, that was just the first truck I came across. I'm not sure if an M813 would have the frame length I want to get a vehicle on without having a lot of rear overhang. I'm thinking something in the 18-22' overall bed length would be about right, with at least 15' flat before the dove.
My first question is: does my reasoning sound solid based on the above? What issues do you all see?
Other modifications I'd plan on making to the truck are adding 16.00 R20 tires on HEMTT wheels. I think this will take care of the overwidth issue on the bridge trucks -- correct? One advantage for the M812 in this respect is the extra rear axle spacing. I'd prefer the tires not to be as close together as what I've seen on the other 5 tons, though I don't think this is a deal breaker one way or the other. Since the tires are so tall though, that would put the bed way up in the air, and I'd have to keep maximum height in mind. My other question about height is stability. Say I bought a larger tractor in the future, would the truck be too top heavy with ~5+ ton that far off the ground? I'm guessing at that point I'd look at getting a trailer.
Thinking about trailers makes me wonder if the the dovetail is a dumb idea because of potential interference between the tongue and the bed. I'd suppose that I could get a gooseneck, except I'm not sure if the truck would end up being too tall for a gooseneck hitch without the trailer being really high in the front, even with the hitch slid all the way up into the neck.
My next question is what should I be looking to pay for one of these trucks? I'm not necessarily looking for something that's mint condition. I also don't want to spend a bunch of money and a lot of time getting to the point where I have something that will pass a MO safety inspection and also not leave me stranded on the side of the road every time I drive it. I would really like to have a winch, but it also wouldn't be a dealbreaker if the price was right.
What options (if any) are there for adding a winch to one of these trucks if it doesn't have one? I'm not necessarily stuck to the PTO winch that these trucks would have came with, but I'm also not sure if I would trust an electric winch to do much good if I managed to get the thing stuck. Would it be possible to add a "wet kit" so I could add a hydraulic winch if I needed to? Is there even room on the front of a truck w/o winch to mount one?
I'm guessing I'll need to buy a bunch of tools to be able to work on one of these trucks, since I'm sure a lot of the hardware is larger than what I'm used to dealing with. To give me an idea: I've got a 1/2" drive air impact, is that adequate for most of the stuff, or is the truck just going to laugh at it? What kind of maintenance should I expect to be doing after I get the truck on the road? I'll admit, I still need to look at the TMs in depth, but I imagine real world experience from you all will give me a better idea of what to expect than trying to read a 400+ page manual. On the same token, what do I need to inspect when looking at a truck to buy?
If you've made it this far, thanks for reading! I'm sure more questions will come up, but I think this is enough typing for tonight.
DougB
US6x4
2,508
Wenatchee, WA
Yeah, that post is well into TLDR territory (too long, didn't read) but i made it to the end...
The M809 series comes with an NHC-250 which is a non-turbo'd 855 cummins so it can be replaced with higher horse engines from that family like the 350 or 400 Big Cam.
The 814 is a long wheelbase cargo truck and may be longer than the 812 - not sure. The M809s occasionally come with the 20,000 lb pto winch and a winch from another truck could be added to one without if you get all the parts but it's cheaper to get a truck that already has one. An M814 W/W would be a XLWB cargo truck with winch, for example.
Bridge trucks have spacers on all axles between the brake drum and wheel that may need to be removed even with hemmt wheels to be narrow enough.
I have 16.00R20s on my 813 and it does make it substantially more top heavy. Floor of the bed is about 5.5' off the ground.
Highest torque I've come across so far is the 450 ft-lbs for the lugnuts and a good 1/2" impact with lots of air can handle it.
Superthermal
1,039
Utah, Murray, United States
I have an M813 and love it. Some items you might want to consider for your choosing.
1.The 809 series 5 speed is not rated for a "hot" motor. I know people who run the HP of a big cam through it but do it "nicely" in an attempt to make it last longer. However, torque ratings are torque ratings and any option you do do with hoping up the engine will lower lifespan.
2.The 809 series transfer-case is an unusual beast. It has the very important to understand "sprag" which demands of the operator to never allow the rig to move backwards when in a forward gear and never move forward in a reverse gear. If you don't follow this or you have a failure of the air valve or sprag actuator the sprag for the front driveshaft will grenade. THis will leave you replacing the transfer-case or a lot of parts.
3.The 809 series bridge trucks were perported to have longer dog bones that if running 16.00R20s would leave you a gap. So far I have only heard people say this is true and I have never seen photo evidence or even measurements of the dog bones so as far as I know of myself this is still hearsay, I started a conversation with a vendor here who gave me interplanetary pricing for these suppoed parts. ThereforeI will eventually build my own either custom dogbones or modify the cast ones on my rig now to get the 5" of gap I would prefer between the tandams to allow chain running on all 6 meats.
4. Making your M809 series rig a daily SAFE work truck... Your going to have some money to put into this even buying a exceptionally well cared for rig. Plan on doing every seal and possibly replace every bearing on the wheels. Also adding a seriously good park brake, as there are obvioiusly for this series no air brakes to keep the rig safely planted when fully loaded. I have heard pinion breaks are fround upon by DOT inspectors and the stock T-case brake is in my opinion a joke for any actual need to keep the rig planted when on an angle of any kind. I have plans to put dual pinion brakes on mine with air release disc brake calipers that are standard on semi trucks now adays. I know someone persionally who put air brakes onto an M809 series and loved the conversion. It is just a safe way to go.
5. Winch. Not sure what you will be using it for so my advice would be limited. If it is only to get you unstuck then you can do any option ofcoarse. I would value the PTO above all as it is solid and has unlimited continuous use capabilities as well as 250' of 5/8" cable. Hydraulic is similar and would require parts from a 939 series to just "bolt-on". With Electric would be by far the simplest to install and to use. but you would definitly want to upgrade the generator to an alternator to something above the 24Volt 60 amp unit it comes with. However most batteries like the 8Ds I run in mine can only handle a 60 amp charge without being damaged, so do your homework. For me, I want the PTO, even with it being alot of a pain to actually run. The main reason for this is if I ever set up to winch a convoy of 20 or so vehicles up a 100 feet of a steep stretch of mountain side the hydraulic and the electric in my view will have their downsides. Again this is only my unique opinion and if a Stallion 25k winch showed up at my door for free I might just well mount it up. I still need a fair number of parts to get my PTO setup finalized.
6. I do not know enough about the bridge truck width to give you any help there.
7. Your going to spend some serious money. Like lots of it getting your rig the way you want. LIke more money than you want to spend and then more from there. From wipers to fuel lines to power mods to exhaust, to seals, to cab features to headlights to paint, to tires, to lugnuts, to wheel studs, like nearly 15 gallons of gear oil aint cheep, batteries, wire, filters, Fuel, Oh ya you need to pay for fuel by the mile... to tools... yes lots of bigger than anything you owned before tools, and everything is double or tipple to ship because it weighs 100 or more pounds for anything. LOL... and the list that I made myself is like miles long and I am working on it with that twitching eye and half baked smile. ;)
8. My M813 is freaking cool. It wheels incredibly well for a 23,000 lb rig. Wife thinks it is a waste of money and time... and has got me in hot water with the love of my life several times already. LOL. The reason I chose the M809 series over the 939 series is simple. Money up front was higher for the 9 series and I didn't like all the extra parts on the 9 series. The 809s are just more basic and therefore have bonus of simplicity and drawbacks of... not sure but there must be some like air brakes, cab size and stuff like that. The 809 fits right in with what I wanted. I did spend significant time looking at rigs from the MK23 down to the M35s. The 809 fit what I was looking for best. But I am not everyone. One of my friends has a ROPS M939 series and it is awesome too and another has the M35 and it rocks as well. Hard to go wrong with a 5 ton.
My 2 cents. Best wishes and good hunting.
msgjd
4,096
upstate ny
please don't forget rolling backwards in neutral is also a no-no for the sprag ;)
i know you know this , but the poster needs to understand the sprag poppet is activated by the transmission lever reverse position and by its neutral position.. Neutral position takes care of the fwd gears by default
G744
4,145
Hidden Valley, Az
Too bad you're way East in MO.
I have a 5-ton tractor, Mack END673 engine (the best, BTW). It's a project rig, and needs to be put together.
For my asking price of $1,500 here in AZ, it's not a bad deal.
Also FS is an 900-series hydraulic winch for an additional $500.
If interested, shoot me a PM and we can go from there.
Dennis
db72
42
13
Palmyra, MO
Good evening (er early-morning),
Thank you all for the information! Let me try to go through this more or less in order. Again, I apologize for the long posts.
First, I'm thinking that I'm probably best off getting something usable and on the road before I start thinking about getting more power than what the NHC250 has.
As far as the M814 goes, I am aware that they exist, but I haven't found any that have a winch. I was under the assumption that the M812 and M814 were the same wheelbase, but I'm not totally sure on that. I've looked around to see if I can find drawings for the different chassis but haven't had any luck. I understood that the M809 chassis was standard length, M810 was short, M811 was long, and M812 being a special long chassis used for the bridge trucks and other platforms too.
I think the wheel studs are longer to accept the spacers too. If I ended up needing to remove the spacers would I have any issues there?
Sounds like the bed floor will be about eye level for me haha - good to know.
How does the air system on the truck keep up with using an 1/2" drive impact? I'm guessing you have to be patient waiting for the pressure to come back up, but does it work good enough if you need to change a tire in a pinch?
I hadn't considered the torque rating on the Spicer trans. I figured whenever I got to that point I would try to swap the engine and trans at the same time and end up with a 13 speed Eaton or something similar. I'm aware this creates issues with the transfer case, etc. but I'll cross that bridge when I get to it.
I was not aware of the issues with the transfer case sprag when moving the truck. I will definitely need to look into that some more. Is it sensitive enough if you roll back a couple of inches taking off at a stoplight or something like that? My understanding of the sprag is this:
-When travelling forward the sprag ensures that the front driveshaft, and therefore the front tires, is always turning at least as fast as the rear.
-When going around a corner, the front tires travel a longer distance so the front driveshaft ends up spinning slightly quicker than the rear.
-The sprag 'freewheels' and allows this to happen without issue.
-In slick conditions, if the rear wheels start to slip, this will cause the rear driveshaft to try to spin faster than the front.
-When this happens the sprag locks up and power starts getting sent to the front end.
-There's some type of actuator/linkage between the trans and transfer case that accounts for the opposite rotation direction in reverse.
Based on what I described above, I am assuming that if you are moving backward in anything but reverse, or rolling forward in reverse, you have the potential to put the sprag in a bind which can grenade it. Am I understanding this correctly?
If I do end up looking at the M812, even if I don't buy it, I'll take a bunch of measurements off of it. I'll be sure to at least get the center-center distance on the axles and I'll try to get the dog bones too.
Doing every wheel bearing and seal on the truck does not sound like a lot of fun.... oh well. I had noticed that quite a few pictures of M800 series trucks have the wheels chocked. I suppose I'll have to carry around a set of chocks until I can come up with a better parking brake solution. I would be interested to hear how the air release disc pinion brakes work, so I'll be checking out your threads in the future @Superthermal .
Being in a convoy of 20 or so vehicles up a mountain side sounds like a whole lot of fun, but I think I need about 20 more friends to make that piece happen haha. I definitely don't want one of these vehicles for it to be a pavement princess. If I don't have a recovery option, that limits where I'd be willing to go with the truck - especially as I learn what it is and isn't capable of.
On the cost piece, I was assuming this would more or less be like a boat: sucking up money every chance it gets. As far as initial purchase cost goes, the trucks I've been looking at so far have been in the range of $4-5k for ones that look like they have been sitting a long time and need a bunch of work, and way on up from there. Specifically, the M812 I have mentioned a bunch of times that I'm thinking about currently is asking $7500. I know it's hard to price things out without knowing all of the details, but does that sound reasonable?
Good to hear. It sounds like you and I are probably thinking along similar lines with what we're looking for in a truck. There are definitely benefits and drawbacks to each of the these different trucks, but right now everything I've seen points me to the M809s. This is only my first military vehicle after all.
Dennis
@G744 The price is certainly more attractive to me than what I've seen up to this point. I really don't know much about the Mack engine. Is it an M52A1 then? I'd send you a PM, but I don't think my post count is high enough yet.
Thank you all again!
DougB
msgjd
4,096
upstate ny
1; How does the air system on the truck keep up with using an 1/2" drive impact? I'm guessing you have to be patient waiting for the pressure to come back up, but does it work good enough if you need to change a tire in a pinch?
2 ;,,, I was not aware of the issues with the transfer case sprag when moving the truck. I will definitely need to look into that some more. Is it sensitive enough if you roll back a couple of inches taking off at a stoplight or something like that? My understanding of the sprag is this:
3: -When travelling forward the sprag ensures that the front driveshaft, and therefore the front tires, is always turning at least as fast as the rear.
4 ;-The sprag 'freewheels' and allows this to happen without issue.
5" -In slick conditions, if the rear wheels start to slip, this will cause the rear driveshaft to try to spin faster than the front.
6 ;-When this happens the sprag locks up and power starts getting sent to the front end.
7: -There's some type of actuator/linkage between the trans and transfer case that accounts for the opposite rotation direction in reverse.
8: Based on what I described above, I am assuming that if you are moving backward in anything but reverse, or rolling forward in reverse, you have the potential to put the sprag in a bind which can grenade it. Am I understanding this correctly?
9: I really don't know much about the Mack engine. Is it an M52A1 then? I'd send you a PM, but I don't think my post count is high enough yet.
1: onboard air will do the job for brief bursts .. you are better-off with a 3/4" impact , a fast powerful burst to break them free .. A 1/2" impact requires a lot more patience and sometimes will not break some of the nuts free no matter what
2: rolling backwards or forwards "a couple inches" in the wrong direction will not harm the xfer case, however it will start to bind if it's a couple feet and more .. BTW, rolling backwards at a stoplight on a hill is an instant road test fail , longtime commercial driver and a former army road test examiner here ;)
3: the sprag doesn't "ensure" anything is turning faster or slower .. The sprag spins freely and unlocked until the the rear driveshafts spin faster than the front driveshaft due to wheel slip, and then the sprag locks in .. Sort of like your Snap-On ratchet or n over-running PTO clutch .. The minute the front shaft is spinning faster or same speed as the rear shaft, it unlocks.. You can actually feel it kick in and out on spotty slippery road as you're pulling a hill
4: yes, sprag "freewheels" as long as the front shaft turns faster or same rpm than the rear shaft , again like your snap-on ratchet freewheeling when you spin it back for another bite
5 & 6: yes, if the rear driveshafts spin faster than the front due to wheel slip, the sprag will empower the front drivershaft
7: No actuating linkage on these 5-ton's .. A poppet air valve on top of the transmission tells the sprag you're either in reverse or neutral (neutral covers the fwd gears by default) .. When putting shift lever in reverse, the poppet sends air to the sprag shift cylinder mounted on the transfer case to shift the sprag into reverse.. Shifting into neutral releases the air to the sprag cylinder and a heavy coil spring inside the sprag cylinder is supposed to return it to default position
8: rolling wrong direction can put it in a bind, yes, if there's air in the system .. Or if the sprag stayed stuck/engaged even after the air bled off, a rare situation but it can happen ... Damage to the sprag (and/or xfer) can happen if the tension is not released within a short distance, preferrably less than 25 feet, most-critical on blacktop .. Some of us who've bobtailed tractors in the military may have experienced the "Hop, Skip, and "BANG!" dance on hard surfaces when the sprag didn't respond to a direction change, it bound up , then violently released itself .. But usually you can feel it binding at low speed starting out, since the truck will act like brakes are on when you go to grab the next gear .. Another symptom is the front wheels making black marks on pavement or scuffing up a gravel road. ..
It's not a problem with a maintained system unless you roll too far in the wrong direction .. But the poppet valve "psst" and sprag shifting " thunk" sound are something to always listen for, and stay mindful of the other symptoms
9: yes, the Mack engines denote the A1's , however i have experienced A2's purposely repowered with macks in certain army units but those still had their "A2" dash tag
98G
Former SSG
4,880
Regarding tire change tools...
Here's the ideal set up -
Military issue geared lug wrench.
Large ratchet and 1.5" 6 point impact socket.
Two 20 ton bottle jacks.
Plenty of cribbing.
The geared wrench breaks them loose. The large ratchet spins them off. You need two jacks because you need more travel than one provides.
There are other "right" answers, but this is what I prefer.
Superthermal
1,039
@db72 Like what is being pointed out there are some things to know about each type of MV. Every one has some + and - to it. We are all excited for you, but do be warned you will be spending a significant amount of time and money and money and money getting your rig solid, safe and rolling.
On the M812 your looking at I heard many of those came with Detroit lockers in the rear axles which could be a solid plus if your into that. Best wishes
db72
42
13
Palmyra, MO
3: the sprag doesn't "ensure" anything is turning faster or slower . It's the front axle which is geared to spin the front driveshaft faster than the rear driveshaft. The sprag spins freely and unlocked until the the rear driveshafts spin faster than the front driveshaft due to wheel slip, and then the sprag locks in .. Sort of like your Snap-On ratchet.. The minute the front shaft is spinning faster than the rear shaft again, it unlocks.. You can actually feel it kick .. n and out on spotty slippery road as you're pulling a hill
4: yes, sprag "freewheels" as long as the front shaft turns faster than the rear shaft , again like your snap-on ratchet freewheeling when you spin it back for another bite
7: No actuating linkage on these 5-ton's .. A poppet air valve on top of the transmission tells the sprag you're either in reverse or neutral (neutral covers the fwd gears by default) .. The poppet sends air to the sprag shift cylinder mounted on the transfer case
1. Now that I think about it, my Dad won a lot of air tools at an auction a while ago. Included are a couple larger (3/4" and 1" dr.) impacts, and I'm sure he would let me use one.
2. Okay, that makes sense. Also, that's good to know on rolling back when starting on a hill. Obviously I try not to, but I'm also not perfect. As a side note, I don't have my CDL and am hoping to get away with not needing it, but I still need to call the DOT or find a trooper to talk to and make sure my understanding of the law is correct.
3. Yeah, I didn't word my post the best, but I get what you mean. I found another post with some good info that says the front is geared 6% faster than the rear. It went into a little bit of detail about how to effectively get the t-case into neutral by bleeding off the air pressure and pointed me to the TM to figure out how to do that. I'm guessing that the "front axle lockout" referenced in the post is a modification that I would like to make. I bet that feeling the front engage and disengage as you describe is an interesting feeling.
4, 5, 6. Check
7. Gotcha. That makes sense with what I was reading in the post I linked in #3 about being able to dump the air to the transfer case and effectively disengage the forward and reverse sprags at the same time.
8. That's something that I will be sure to pay attention to. I'm glad that you pointed out the symptoms so I know what to look for. It sounds like it will also be important to occasionally "exercise" the air poppets in the transfer case to help keep things from sticking. I.e. if I added a "front axle lockout", I shouldn't continually leave the air dumped. Either way, checking the operation will be on my list of things to check upon acquiring a truck.
This brings me to a new question: Is there a way to easily verify the transfer case is working properly when inspecting a truck to buy? Listening for the poppet valve "psst" and sprag shifting " thunk" would be good, and it seems like if the sprag is not disengaging, that would be easy enough to spot based on the info you gave. I'm not sure how I'd know that the transfer case was engaging properly until it snows or maybe I find a mud puddle.
9. Okay, that makes sense. Seems like Mack vs. Cummins is a matter of personal opinion like everything else reading other discussions here. One thing I like hearing about the Mack is it sounds like it does a lot better at low rpm than the Cummins does. Parts availability and price sounds like a major plus for the Cummins. I suppose if the price is right I'd be open to either. I'm pretty sure I don't want a multifuel in a 5-ton though, which seems like what's in most of the M39 trucks I've seen.
Thanks,
DougB
98G
Former SSG
4,880
4, 5, 6. Check
Thanks,
DougB
@firefinder might know about MO's CDL requirements.
db72
42
13
Palmyra, MO
Plenty of cribbing.
I will have to look into getting all of those things together. The large ratchet, 6-point socket, bottle jacks, and cribbing all sound like I would need them no matter what. The geared lug wrench sounds like a good idea from a "having options" standpoint too. I'm guessing that I will spend some time with the truck and a couple different methods of removing wheel lugs to figure out what I like best.
Thanks,
DougB
98G
Former SSG
4,880
Thanks,
DougB
Every time steel soldiers gets a new member wanting to get a truck, we all live vicariously through it...
db72
42
13
Palmyra, MO
Yeah I'm expecting this to be the type of thing that sucks up money every chance it gets much like a boat. Having Detroit Lockers already installed would be fantastic! I haven't looked into what they cost for these, but those are definitely something that I would look at having in the future.
Thanks,
DougB
db72
42
13
Palmyra, MO
@firefinder (and everyone else who may be interested) my understanding of MO CDL requirements was that I could drive a "Commercial Vehicle" without a CDL if I was using it for personal reasons. What's considered a commercial vehicle seems to be pretty straightforward: a single vehicle with a GVWR of 26,001 lbs or more (5-tons should fall into this category). The "personal reasons" part seems to be a little more vague. One scenario is if I bought a car and hauled it home with the 5-ton, I don't think this counts as commerce since I'm transporting personal property - law enforcement may disagree.
I found the actual law that referenced what I'm talking about on a mo.gov website at one point, but I'm not seeing it right now. In the MO CMV manual though, under "Exemptions" it states:
"Any person driving for personal use, a commercial motor vehicle while transporting personal property, such as household goods of his/her own or another"
If someone thinks I'm blatantly wrong on something here please let me know.
Thanks,
DougB
