Battery balancing
ufoDziner
25
13
Las Vegas, NV
I'm swapping out my bad 400A generator for an alternator. When doing this, I'm going to add a 24V-12V DC/DC convertor to run the stereo I plan on installing, etc... The plan is to run the 12V transmission power from from the stepdown converter as well. From what I can tell, there is no system in place for battery balancing. While they really shouldn't get too far out when using a converter, I'm curious if anyone runs a battery balancer to ensure the batteries are matched, and if so, which one do you use. Thanks.
ufoDziner
25
13
Las Vegas, NV
With this swap I'll need to update the wiring a touch. There are three wires with yellow ends (pic attached) that appear to be for the 12V side of things. I'm new to the manual system with these, so if someone could direct me to the manual and section as to where it shows what these wires connect to, I'd very much appreciate it. Additionally, there is this unit bolted to the side (in second pic, circled in blue) that I can't identify. Again, any help is welcomed. Thanks.
155mm
Chief and Indian
472
Guymon, OK
I dont have any input for the battery balancing,
I can help with your second post about the wiring, besides this photo, a full schematic can be found at the back of the 280-20-3 under the FO or foldout section.
Your second photo is of the grounding shunt. here is a thread with some info, https://www.steelsoldiers.com/threads/hmmwv-ground-shunt.75497/
Shunt is also described in 9-2320-280-20-1 Sec 2-16 page 2-40
ufoDziner
25
13
Las Vegas, NV
I'm getting ready to install my replacement 160A alternator and noticed that my current wiring doesn't match the diagram. It appears that the 400A generator is wired up a bit differently than the 200A and all of the diagrams I've found are for the 200A. Does anyone have a wiring diagram for a M1165A1 with a 400A generator? I'm currently using the one in this packet. Thanks!
