M1009 fuel tank builds vacuum when driving
Sezzo
301
Bamberg (Germany)
Good morning everyone.
I used the search function very well but could not find what I am looking for.
My M1009 builds a vacuum in the fuel tank when driving. It does not vent properly obviously. When I open the fuel filler cap after driving I can clearly hear a „pfffff“.
What is wrong here?
Thank you very much in advance.
Sharecropper
1,207
Paris KY
Your fuel return line from the engine is either stopped up or kinked, thereby not allowing the excess fuel to be returned to the tank. Your fuel pump is sucking fuel from the tank which is causing the suction. Clear the obstruction in the return line and the problem should be solved. Just my 2 cents.......
Sezzo
301
Bamberg (Germany)
Not kinked anywhere. Maybe some gentle compressed air will help to blow it out? And where should I loosen it to blow it out?
Sharecropper
1,207
Paris KY
The fuel return system starts at each injector in those small flexible hoses that jump from one injector to the next. All these are routed to a hard line on each side of the engine which runs over the water pump and exits the engine just above the fuel pump on the passenger side at the front bottom of the engine. At the end of this hard line there is a 1/4" rubber line which connects the hard line on the engine with another hard line on the frame which runs back to the tank. If it were mine, I would disconnect this rubber line, remove the fuel cap, and direct compressed air into the line going back to the tank. This should clear any blockage in the return line. Hope this helps.
WWRD99
1,911
York Pa
I read to drill a small hole in the fuel cap fixes it? What do you think?
I guess you could do that. I just got new used ones when it did it. They'll build pressure on a low tank on a hot day, too. Could be you're getting pressure and not vacuum in the tank. No way to really know.
Sezzo
301
Bamberg (Germany)
Thanks to all of you. Helped a lot. I will start with gentle compressed air to clean out the vent in the filler cap and go from there. Return line is next if that doesn’t help. Buying another cap is the last option because they are crazy expensive in Germany - about $250
WWRD99
1,911
York Pa
Leave the cap loose or swap them first.
PHOENIX-GER
1,095
Germany
@PHOENIX-GER might be someone for you to talk to. She might be able to tell you where to get a cap cheaper.
To find one in Germany maybe very difficult. Where did you got one in Germany? We have installed a second original tank (sattle tank configuration). The tank, sending unit, necessary Army fillerneck complete with cap and all other needed parts did i got in the USA all new except the fillerneck, this was only in a very good used condition available.
I would check all other reasons like sharecropper mentioned before drilling a hole in the cap ....
We are looking for a cap which i can lock. Not available anywhere. We check truckcaps which could have a fitting size.
