NO START.. M1031 12v Doghead
32
10
Vancouver, WA
Hey guys.
So I haven’t driven the truck for a while so I charged the batteries and tried to fire her up, and nothing. Back story it’s an m1031 that got molested by a kid, block and generator scraped, converter to 12v starter.
All I can hear is the clicking on the Napa part# 7-01860-1 solenoid from the doghead mod which worked before. I thought the solenoid went out so I replaced it and still nothing, just that click.
I also arched the starter to make sure it was good and it is.
I checked voltage going to the Napa solenoid and it’s good to go, 12v constant (red wire) and 12v when I turn the key (purple wht stripe wire) and purple wire that goes the starter solenoid.
What else could have failed that ain’t allowing me to start this beast?
thank you in advance
WWRD99
1,939
York Pa
Hey guys.
I checked voltage going to the Napa solenoid and it’s good to go, 12v constant (red wire) and 12v when I turn the key (purple wht stripe wire).
You should be able to jump the big red and purple wires on top of that relay and get the starter to go. Fat screwdriver works.
sneekyeye
142
ALABAMA
Make sure your 12v is getting to the starter solenoid from the relay. If you manually triggered the starter with a screwdriver and it spun strong, the ground and supply sides to the starter should be good.
WWRD99
1,939
York Pa
how can I check this? I did manually arch the starter from underneath the truck.
You know if the starter is clicking or the glow plug relay? What's clicking. The doghead relay shouldn't be clicking. If you can jump it underneath at the starter, then giving the same wire power should start the truck.
sneekyeye
142
ALABAMA
The purple wire should run all the way to the starter solenoid. When you turn the key and get 12v on your purple wire at the doghead relay, you should also then have 12v on that wire at the starter. If you don't, then you have a connection issue in the wire somewhere. If you do have 12v at the purple wire and on the stud when you turn the key to start, then that likely points toward the starter, as long as the ground connection from the block to battery is known good.
It can be tested off the vehicle pretty easily to confirm if it looks like a starter problem.
32
10
Vancouver, WA
The starter relay is clicking not the glow plug relay. That’s on a manual button.
WWRD99
1,939
York Pa
Ok. If the relay is clicking then you're testing the wrong side. You need to cross the 2 wires on top of the relay. They're the controlled side. If you have a volt meter with the key on the red wire on top should have 12 volts. Maybe the fuse going to that wire doesn't have power.
32
10
Vancouver, WA
I FIGURED IT OUT!!
The damn small wire to the starter was melted against the header. I pulled it off and it actually started. Now to rewire the damn thing so it doesn’t do it again!
thanks for your help guys. Sorry for the confusion.
deank
687
Inverness, Florida
On mine, I pulled the small wire out of the engine harness, then I made it longer and put a single wire connector on it. The other side of the connector went to the starter. That way when I have to remove the starter, I disconnect from the starter at the connector rather than struggling to get the wire off the starter.
antennaclimber
1,093
State College, PA
I did the same thing to my M1010 during the rebuild.
