Help Troubleshooting Potential Sticking Metering Valve
huskerfan
14
Lincoln, NE
Hi Guys - looking for some input on a potential sticking metering valve on my IP
I swapped a used IP into my M1028 a few months ago. The fuel screw on it was turned up all the way due to it coming off of an old 6.2 that had a turbo on it. Timing on it is about 2 line width's advanced. It still idles a bit rough, so i know i need to mess with the timing a bit, but I was on a time crunch for an offroad trip so i left it as is. I accidentally almost had a runaway incident when i adjusted the timing the first time and accidentally bumped the starter without the governor in the IP. That was scary, but choked off the intake and pulled the fuel supply line within a few mins, and got it all back together and it ran fine. Only issue now though is that after the truck sits for a day or so, upon first fire up, it'll idle just fine, but once i give it throttle to back it out of the garage, it'll stay stuck at that throttle position even after i let off the gas, and then then i shift it to park, it starts to runaway. I shut it off, and fire it back up, and then everything is normal and i wont have any issues the rest of the day. Only thing i can think of is that the metering valve is sticking or something maybe?
One other thing to note is that the check valve on the return line off of the IP i bashed out the glass ball inside during the offroading trip because it was all gummed up and the truck would not stay running. Not sure if that would cause this issue with it running away upon first start up and throttle input?
Barrman
2,244
Giddings, Texas
If you had to bash out the internals of the return line check valve. Your injection pump is coming apart inside and needs to be rebuilt. Getting that done will probably fix your problem.
Another thought I has was your fast idle solenoid. Do you push the throttle about half way down after turning on the ignition switch but before starting a cold engine? If so, your fast idle has been activated and probably adjusted correctly. However, if you don’t let the solenoid move to the fast idle position before starting. You could have one that is way out of adjustment and when you give it a little throttle to move the truck, it engages and is holding the throttle open.
I still think you need to get your IP rebuilt, but check the fast idle solenoid adjustment if you haven’t been using it on purpose.
huskerfan
14
Lincoln, NE
That's what i thought when i bashed it out was that that debris in there was from the IP failing or so i thought i read that on these forums.
That's the weird thing too is that my old IP, the check valve was clear, but it would die after you let off the throttle. Thought it was bad internals and not returning the governor spring to normal position. New IP i swapped in didn't have that problem, but now has this new problem.
But no, when i go to start it, i do key on, wait for the glow plugs to cycle and turn off, then it fires right up. No throttle input required....
Barrman
2,244
Giddings, Texas
The fast idle solenoid is not powerful enough to move the throttle lever on its own. Any time the key is on and the coolant temperature is below 94° the green wire to the fast idle solenoid should have 12 volts. If you don’t touch the throttle after turning on the ignition the fast idle solenoid is armed and ready to deploy but can’t until you punch the throttle down about 10-30%. When you do push down on the throttle and the coolant is below 94° that solenoid is going to pop into position. Properly adjusted that means your idle will be about 800-900 rpm. It could be turned down though so that it will be holding 20-30% throttle. Which with no load could get you way up there in rpm’s.
Pull the drivers side sun visor down and read the starting instructions. It tells you to push the throttle down after turning on the key. A lot of people don’t which is why I asked.
Try unplugging the green wire to the fast idle solenoid and see if the high rpm event happens then. If not, use a 12 volt jumper wire from the front battery to activate the solenoid with the engine off. Move the throttle arm until the solenoid jumps. If the throttle arm is now being held far away from the idle screw, turn the plunger/screw in the middle of the solenoid until the throttle arm is just a little bit above the idle screw. Then move to adjusting it with the engine running until you think you have about 800-900 rpm as the sticker on the side of the air filter says.
Sharecropper
1,290
Paris KY
I strongly suggest that you postpone that off-road trip until you get this issue fixed. Ask me how I know.
