Summerpaws
- 154
- 33
- Hampton, NH
Ok. I found the smoking gun. I removed both wires from terminal 3, K8. Wire 166B goes to J6-3. Wire 166C goes to R12-1. I unplugged P6/J6. R12 is open circuit. R13 is 7.9 ohms. Double and triple checked readings. Seems I need a burden resister. Thoughts?Look in the control panel. The plugs are on the Bottom of the control panel.
First take the wire off K8-3, and measure from there to the Burden Resister. If you get nothing, then unscrew P6. Look at the schematics to see what pins to check in P6/J6.
P6/J6 can also be loose, or have a bent/burnt pin. Open the lower door s lay on your back with a light and inspect.
