Can you service a turret bearing?
alwayskaos
21
Lake Havasu City, Az.
So I have a used heavy duty turret bearing and was wondering if anyone knows if you can service these. I can't see anywhere how it might come apart, but it makes a little noise when spinning. Can you service these and is there a way to disassemble? Thanks!!
BLK HMMWV
568
Pasadena California
A picture of the bearing would help. I'm not sure if all the bearings are the same.
The earlier black bearings have a round plug / seal in the inside surface of the bearing ring. Slightly larger then the ball bearings inside.
In order to separate the two halves of bearing you needed to remove all the balls.
KKroger
160
KC MO
The Correct answer is ,,,, Maybe. you would likely want to wash the old grease out and put new in and if it is a sealed bearing that comes with complications like the seals.
alwayskaos
21
springer1981
1,183
Maine
Find TM 9-2320-280-20-3 Volume 3 then find section 11-113, Page 11-158
It describes the maintenance. I copied the page. Note the first step includes "Discard Seals" meaning you'll need new seals. I'd try to find them before continuing.
