MEP-804B Starting issues
Darren allen
Lakeland, Florida
MEP-804B I had a problem getting it started after purchasing turned switch to start and only click sound from relay, finally started after hours I don’t know why it decided to start, started multiple times that day after a week of not starting it went back to doing the same thing and haven’t started since . I would appreciate some help with this issue thanks.
Scoobyshep
2,240
Florida
Are you comfortable and or competent with a voltage meter?
On the back of the starter there's two large studs one is always live with 24 volt that goes to battery the other one goes to the motor you're also be a little wire on the back of the starter that's the trigger. Have a helper hold the switch and start when it fails to crank and measure the voltage on these three wires to ground. This will help determine whether it's a starter issue or a controlling issue
Sent from my SM-S908U using Tapatalk
Scoobyshep
2,240
Florida
Just noticed youre in Lakeland, Im near altimonte, If you get completely stuck I could find my way down there.
Darren allen
Lakeland, Florida
Good morning, positive stud 24V and stud to starter 2.8MV trigger wire 2.8 MV while held to the start positio.
