How to get an Allen key between the starter ring gear to measure the distance - M1009 / Chevrolet Blazer K5 6,2 Diesel
Elektroman99
138
Siegburg, Germany
Dear Steel Soldier Community,
I have a very serious comprehension problem.
In this thread I had discussed a starter motor that was constantly coming loose and we quickly found out that the rear fixation was simply not fitted and the starter motor is only fixed to the two strong bolts directly on the ring gear housing.
In this thread post there was a good video on how to test the distance from starter to ring gear. In the video, an Allen key is inserted between the engine starter flywheel and the starter shaft. In the video without the ‘rest’ of the car (engine) this also works. In my case, however, the starter motor sits in the housing of the starter flywheel (ring gear).
The photo shows my view when I'm lying under the vehicle and looking upwards.
How or from where do you get an Allen key in between?
What am I doing wrong?
Best regards
Elektroman99
WWRD99
1,925
York Pa
You have to remove the torque converter cover to see the gears. Why do you want to do that check?
Elektroman99
138
Siegburg, Germany
The protection is this metal cover sitting in front of it, right? How many screws are there (in total) and is there anything to consider when dismantling - and later reassembling?
Why I want to do the check... well... the starter motor wobbles when I tighten it. This means that when I tighten the front or rear screw, the starter motor rocks. Now and then the rocking is enough to cause the starter gear to slip.
I'm going to completely dismantle and clean it tomorrow and then wanted to adjust the distance and realised today that this distance measurement is not that easy. So with the mudguard in front of it ‘not at all’ possible. (Damn)
WWRD99
1,925
York Pa
Yup gotta take that cover off. It's 6 bolts on the outer edges then the ones that hold one the transmission lines. Those lines run right over that cover and have to be bent out of the way or unbolted from the trans to get the cover out. Either way is not easy. Can damage the lines bending them or have a night mare removing them from the trans. So question is...this wobble you want to fix. With the front bracket installed there should be no wobble or much in the starter bolt holes. Did you get a new starter or bolts since you found the front bracket missing? It may have egg shaped the guide holes in the starter. With it bolted in it should not move if it does you have other problems you have to fix before you play with a little clearance on the gears.
Elektroman99
138
Siegburg, Germany
I have new screws here, but I haven't used them yet. I also have the additional bracket here and have realised that the screw on the engine block has only been screwed in.
OK... I now have the problem that when I use the old screws, the starter motor wobbles as described. This means that if I tighten it a millimetre incorrectly, the starter gear slips.
So I'm going to remove the starter tomorrow and clean the engine block and screw. Then tighten it and ‘pray’.
WWRD99
1,925
York Pa
Ok, you found a few problems. Gotta use the correct starter bolts that are knurled on the middle by the threads. Those align the starter to the flywheel. My fear is that the holes in the starter are no longer round but egg-shaped from moving around. The starter will not work if they are. That front bracket is just as important as putting oil in the engine. Without it, it will break. Get the starter installed correctly and you'll have no more problems with it. Every starter I install gets new bolts in the starter and bracket.
Elektroman99
138
Siegburg, Germany
The screw that is supposed to hold the transmission lines is already missing. That was a question I couldn't even ask at the moment.
If the holes are slightly "egg-shaped", is there a way to repair it without changing the whole starter motor?
Can anyone provide a source of supply for the bracket here or a valid material number?
WWRD99
1,925
York Pa
You'll probably need a new starter. With the holes not right it won't line up properly. There's a bunch of those brackets for sale on ebay Amazon etc.
Elektroman99
138
Siegburg, Germany
I have the problem that the starter motor no longer fits exactly and it is pure coincidence when the teeth engage correctly.
I assume that the bolt holes in the starter motor have been worn out due to use without a 3-bolt bracket and no longer fit properly.
My engine wash probably loosened so much dirt that the starter motor then shook loose.
I tried using an ‘04’ smudge disc, but the teeth didn't grip here either.
So I need a new 24v starter.
Once again:
Can anyone tell me where I can order the screw and the bracket on the right as a spare part?
Elektroman99
138
Siegburg, Germany
Unfortunately, the previous owner had not installed the third bracket on his starter (already a copy of an original military GM starter).
After cleaning the engine and finding that the third bracket was missing, the starter motor was loose after 6–10 starts.
After being advised to check the holes in the bolt guide in the starter head for “deformities,” I noticed that they were “egg-shaped.”
I purchased a new replica of a military 24 V GM starter motor.
Then the issue arose that the starter ring was now so “worn” in some places that the new starter motor no longer engaged, despite being correctly seated.
A new starter ring gear was installed in a specialist car repair shop – unfortunately at great expense – and now it starts again without any problems.
Is it possible to buy just the starter head, as the starter itself is still functional?
87cr250r
2,131
Rodeo, Ca
The starter head is available to be purchased on its own. I think I paid $19 USD for one. You'll have to purchase it through a shop that specializes in starter repair.
Elektroman99
138
Siegburg, Germany
Hello,
Thank you for this information.
Can you name one or two shops for me? I can't find any that offer these “heads” or individual parts for the starters.
Maybe I'm searching for the wrong terms on Google?
Best regards
Elektroman99
