Just won an auction - M1088A1
dwlindsey
143
California
I just **FINALLY** got the passenger side front cab mount bushings replaced. My 3/4 inch Dewalt impact was not loosening the nut on the bolt. So I bought and applied an Induction Heater. No luck. Propane torch . . . no luck. Then I tried chilling the bolt, no luck. Then a 3 foot cheater on a breaker bar, no luck.
Today I bought 6 feet of black iron pipe and applied it to a 3/4 breaker bar. With my son pulling on the end of the cheater and a significant bend in the pipe, we had a small movement and a loud crack like something broke. Turns out it was the rust or locktite on the bolt . . . the Dewalt took the bolt right off.
From there the only issue was getting the right amount of cab tilt so that the thread on the bolt was exposed enough to thread the nut on.
5 sessions with this and FINALLY today we got the nut off the bolt. The top bushing was gone. The lower bushing was compressed about 50%. When driving I'd get, not surprisingly, a clank and cluck from that location. I'll drive it again tomorrow and see how it sounds and feels.
Sometimes the simple things, like getting a nut on a bolt loose, are the hardest
GeneralDisorder
6,174
Portland, OR
I broke a 1/2" breaker bar anvil on the cab bushing nut. Bent the HECK out of C-clamp doing the rear sway bar bushings. The ones that go around the bar itself. That's an ugly job. I think the worst jobs I've done though were the engine mounts, and the sum total of the AC install is pretty tiring. I mean I did it over like a year - finding the parts and sorting it all out perfectly was tiring. And fitment of "reproduction" parts like the compressor brackets....
And of course tire mounting. That's just a good time and best with friends if you can bribe them to participate.
dwlindsey
143
California
I've got most of the stuff for the AC install. I'm still missing the original OEM condenser, but I've got one that will probably work. I'm not looking forward to it, but my "plan", such as it is, is to tackle it one bit at a time. Compressor on one weekend, heater box removal on another weekend, installing the evaporator another, making the brackets for a condenser . . . It's getting cooler now so I don't really need to finish it before next summer . . .
Oh . . . I also don't have a wiring harness, so sorting out the wiring is going to be an interesting puzzle
AKPacker
226
Anchorage, AK
Yeah those cab bushing bolts can be a bear, I still need to tackle the driver's side on mine. I replaced the lower passenger side one with a MME repro earlier this year and it is already cracking...
I'm jealous of you guys with your A/C units, at this point I think I'm going to have to wait it out until some of the A1P2 units/parts start to show up at auction.
dwlindsey
143
California
I installed the MME bushings . . . we will see. Now that there's some anit-seize on the bolt, replacing it should be simple when it happens.
MME is offering an air conditioner that will be easier to install than the original OEM, because they have the full kit. As I recall the evaporator sits behind the heater box in the lower part of the engine hump.
I was able to find an original evaporator to replace the heater box, I believe it's Gen2, but I haven't verified that yet. It was stupidly expensive and in total I already have parts on hand that cost about what the MME unit is selling for. Apparently a while ago the evaporators were pretty cheap, but now it's a sellers market, if you can find one at all.
I'll need to kludge up a condenser and the wiring . . . so the MME might have turned out to be easier . . .
dwlindsey
143
California
I took her for a drive today.
Passenger side cab bushings replaced, Subaru WRX seats installed, Eco Hubs installed. Air leaks mostly fixed, it holds 110 PSI or so overnight. I did the power cycle 6 times and press the accellerator to the floor on the 6th, to ask Allison to re-learn the shifts.
She's starting to look pretty good and feel pretty good at low speeds. Today I got on a large road with, at that moment, no traffic and nailed the accelerator to the floor. At 60 MPH it was a pretty wild ride. at 40 MPH she's acceptable, but 60 feels pretty bad.
I've removed about 1300 pounds from the rear. So she's very light at the back. I have not yet had the drive shafts balanced and the tires may well be unbalanced.
I'm hoping that the biggest single item is the lack of weight on the back, which will be solved when I put the habitat box on.
dwlindsey
143
California
Raptor bed liner on the floor of the cab.
3 coats of Lizard Skin sound control, 3 coats of Lizard Skin ceramic insulation and today I did one coat of grey Raptor bed liner on the floor.
The Subaru WRX Seats go back in tomorrow.
