'44 GMC CCKW Restoration
Day Radebaugh
26
13
El Dorado, KS
Newbie from Kansas has acquired a truck that has been described as a '44 GMC CCKW. I have no documentation. The truck runs and I intend to restore it. My first question is the shift pattern. The main box (transmission) is 5-speed, with 1st down and to the right, the rest if regular H-pattern. However, the transfer case has me baffled. It has 2 levers. When both are forward, I appear to be in 6-wheel drive low. When left-most lever is back, I think i'm in high-range.
Does anyone have a shift diagram for this truck?
Second question: I will repaint this truck, and want to put Olive Drab on it. Is there a good source for this paint?
Have attached a picture of the old girl at work on the farm. She's a great old truck.
Thanks very much.
Day Radebaugh
26
13
El Dorado, KS
I will look for the data plate. Can you tell me where the frame number is?
My understanding is that the truck was originally an open cab, but was in an accident, and someone replaced the cab. The truck was used to move houses out here in El Dorado, KS.
Thanks
Day Radebaugh
26
13
El Dorado, KS
Are your data plates missing? What is your frame serial number? 1944 is too late for closed cab.
RAPCO for the paint you need.
Many thanks for the pic of the data plate. The truck does not have this plate. Do you happen to know if I can get this made somewhere?
Thanks for the information. I managed to get the left-hand lever (range selector) into high range, but can't seem to move the right-hand lever so as to disconnect front-wheel drive. Is there a trick to doing this?
Day Radebaugh
26
13
El Dorado, KS
Many thanks. Will give it a try.
Huge thanks for that suggestion; it worked like a charm. She drives fine now.
Have attached some pix of the old girl. I'm having her hauled off to the painter today for a new paint job, and then I'll get her back in my shop and start on the cab interior. It's still 6V electrical, and starts fine, although I may convert it to 12V. Original engine, as far as I know. As I mentioned, the cab has been replaced. I included a picture of the data plate in the cab.
NDT
7,471
Camp Wood/LC, TX
It appears the data plate might be correct for that chassis. The "352" part of the number is GM code for short wheelbase, only about 10% of CCKWs were short, and yours is. The B1 means cargo without winch, no surprise there, all shorts were cargos. The 218119 is the production sequential number, it is possible it's a 1944. Sounds like whoever swapped the cab, moved the data plate across to the replacement cab.
