hey guys hope your well. I just acquired an Mep-807a 2009 model year with a cat engine. It’s in great shape and has about 1100 hrs. The bad it throws a code that says high voltage detected on the low voltage side which doesn’t allow it to run unless you do a battle short and bypass it then it will run and produce power. Any ideas or thoughts would be greatly appreciated thanks.
