What batteries do I need
TNDRIVER
577
Cleveland,TN
I have a HMMWV M1123 with a 6.5 non turbo engine looking for what size batteries I need for it any information would be greatly appreciated thank you
6T's from the Government side. Group 24 are the right size height wise. I will not give advise but tell you what I've done. One truck has Odyssey 6t's , one replaced under warranty but will not use them again they have become stupid expensive. The other truck has Wall World Group 24 AGM's . The W W batteries have a better warranty (It seems to change a bit depending on where you live.) and price. The same battery is available from the usual suspects but more expensive. If you use the 24's place some blocking and/or anti skid material under/ around the bottom of the batteries. Works for me.
Milcommoguy
2,419
Rosamond, CA
DITTO with the gorilla guy🦍. Warranty and availability, over the counter at discount stores. Lasts just has long, a LOT easier on the wallet 💰& 6TL's too damm heavy. 🏋️‍♀️
Be nice to them.. They don't have 9 lives. PMCS, don't leave them dead or dry, over / under charged (float) and figure 5 years. My old auto shop teacher said "Wet cell battery has two states. Charged and discharged" Not a very good storage battery 🤔
IMO...Don't monkey around with got's to be OEM, CAMO
Mogman
10,564
Papalote, TX
Do you have a "company" Interstate battery store near you?
If so I would look to see if they have any AGM "recon" group 24, 27 and IIRC someone managed to stuff some group 31 batteries in there.
I have had real good luck with the "recon" batteries which are 99% just batteries that the shelf life has expired on.
I personally would never run standard lead acid batteries in a passenger compartment because of the chance of a hydrogen explosion given the rather sealed battery compartment the HMMWV has and of course if you are ever unlucky enough to roll it then you have an acid spill to deal with although there would be a rather small chance of that happening.
I had a real bad run of Wally World batteries, three that just quit, no warning and no output, but your mileage may very..
Coug
4,803
Olympia/WA
Best: AGM. will hold up better to abuse and vibration than flooded.
Second best: Maintenance free flooded lead acid. don't need checked monthly for fluid level.
Last place: flooded lead acid. Will need checked monthly for fluid level and topped off with distilled water as necessary, will leak if tipped or shaken badly, and when charging (and especially if overcharged) create hydrogen gas and oxygen, essentially turning the battery compartment into a small bomb (and yes, I've seen pictures from the explosion)
As for size, 6T is what the military uses, but that's simply because they use those in larger trucks, and supply chain logistics for that large of an organization it's easier to use an oversized battery than stock multiple sizes. Major downside of 6T is in the civilian world they are considered a Commercial/Specialty battery, meaning a lot of places don't stock them, and they only come with a 6 month warranty. Also much more expensive than a comparable quality group 24 battery, that at minimum comes with a 1 year, and can be found with 4 year full replacement warranties.
Group 24 with flat tops (usually either AGM or maintenance free) will work with the original hold down bracket, making install very easy (there is a 1/2" thick board in the front and rear to keep them from shifting since the positive post is kind of close to the front of the battery box)
thompsoncustom
120
iowa
I see most people run group 24 I personally run group 65 which probably wouldn't work unless u had custom hold downs or don't run them (mine never came with them). But the biggest reason I run 65 series is because that's what I have in every vehicle I own cars/trucks/ and a humvee.
Coug
4,803
Olympia/WA
Basically, any batteries that you can make fit into the battery box, or any other location that you want to use (the H1 uses a holder near the front passenger tire)
The original 6T battery was only rated for around 660 CCA, so anything above that will be fine, though more is better if you live in a colder climate. The H1 uses a pair of 800ish CCA batteries. If I recall correctly RWH (Retired WarHorses) who owns/operates a shop that has specialized in HMMWVs for decades said that one truck came into the shop with a pair of lawnmower batteries and was starting okay, but that is also in California where it's usually warmer most of the year.
The 6T has huge reserve capacity, basically a lot of power that can be used while the engine is off for things like radio equipment. Most of the batteries we've mentioned are 1/2-2/3 the RC of the 6T, but unless you want to operate a bunch of stuff for a long time with the engine off it doesn't make a difference. You can always add additional batteries under the rear seat of elsewhere in the truck to run non-essential equipment if you want to.
Godspeed131
991
Knoxville, TN
I’m apparently in left field lol with group 34s in mine. Currently running Interstate MTX-34 agms. They are a little shorter and not as long so I had to use some highly engineered natural wood decking boards for spacers but makes it fit nicely. So as can be seen pretty much any decent battery will work doesn’t need to be exact.
