- 156
- 176
- 43
- Houston, TX
That is one reason I stay away from that new fangled fancy stuff, plain ol Goodyear hose has serviced me well for the last 50 yearsWell, the damaged radiator couldn't stop me, but the hose clamps did.
The standard "worm" clamps, which I have a ton of, kept tearing this blue heater hose to shreds. Being after 5:30pm on a Sunday, my options were few-and-far between. If I kept experimenting, I was worried I wouldn't have enough left over by the time I finally figured out a solution.
For reference, the replacement hose is by Flexfab 5526-038.
I'm sure there's a simpler and easier solution, but I finally just ordered a few of the clamps recommended by the manufacturer. They should be here in a few days.
Until then, there's enough small things to do to keep me busy.
Looks like you are getting a little too close to the exhaust with that cooler hoseLooking for some feedback.
I've only got a few small items left, so I might as well knock these out while I wait for my fancy hose clamps.
I wasn't able to route the oil cooler hoses properly until now, as the cooling stack just got installed a few days ago. Of course, this would be the one time I didn't take enough pictures, and now I don't remember the exact routing. The -20 and -24P are OK for this, but both could be a little clearer.
Here's a quick rundown of the new hoses and how they're installed. Let me know if anything looks funky or weird.
Hose connections at radiator.
1st clamp at firewall
2nd clamp
Routing past exhaust
Hose connections at engine block (from straight below).
Thanks in advance!
Agreed. It would have been easier, quicker, and definitely cheaper to not get involved with this stuff. I will never touch it again.That is one reason I stay away from that new fangled fancy stuff, plain ol Goodyear hose has serviced me well for the last 50 years
Thank you. This was exactly the input I was looking for.Looks like you are getting a little too close to the exhaust with that cooler hose
The good thing about silicone hoses is they are slippery so they are easy to get off, the bad thing about silicone hoses is they are slippery and hard to keep on.Look what came in the mail yesterday.
These among the most expensive hose clamps I've ever owned.
They look nice enough. They're smooth-side clamps, so they shouldn't tear up these new silicone hoses.
The clamps only took a fraction of a second to install, but the torque needed to tighten down the hose was suspicious. I'm assuming it is because of the hose material, but 35 in-lbs. seems like an awful lot for such a small clamp. Any less than that and the hoses were still slipping around on their fittings.
Ok then. I guess we'll have to see what happens.
When these come flying off, which will be at the worst possible moment, I'm definitely going back to rubber.The good thing about silicone hoses is they are slippery so they are easy to get off, the bad thing about silicone hoses is they are slippery and hard to keep on.
ON POINT! Great stuff when used correctly. Commercial truck shops have this stuff in stock, be forewarned they like it a lot...$$$$$Everything is a trade off. Quality silicone hoses will last much longer and survive higher temps. They have multiple reinforced layers more than plain heater hose. Silicone will not turn hard if sitting up for years with out use. They will also not balloon and swell up on the ends as fast or easily. But as noted ,require the correct double looped clamps. Larger sizes require the torque to yield with springs.
All about $ and expectations. You will find silicone almost exclusively in the hd world.
