M1165 Rear AC Condenser Bracket?
Mogman
10,591
Papalote, TX
IIRC the bracket is built into the condenser, it is held in at the rear by some screws through the top of the fender near the back.
GMVguy
116
Texas
Man I hope so. Will disassemble it a bit more to see where those might attach. Can't find it in the TMs...
Mogman
10,591
Papalote, TX
Actually it can be removed from the cond. but it could still be there and all you need are the screws, notice different part numbers for the left or right side bracket.
Mogman
10,591
Papalote, TX
You should be able to see the bracket through the screw holes in the top of the fender as you push the cond. back into place
GMVguy
116
Texas
Thanks. I saw that in the TM, but believe that bracket is for the front side, which is in place. The rear (angled) side is what's loose. I will take another look for bolt holes from the top.
DREDnot
636
Avondale , AZ
That crude rear bracket holds the rear of the condenser unit up. The condenser unit has a strip of spring steel that just slips over that crossbar.
Its hard to describe and impossible to photograph it in place.
In this pic the spring steel sheet metal with the green dot just slides up over that bracket cross bar. The only thing that holds it there is gravity and the three bolts in the top forward bracket of the condenser unit.
Mogman
10,591
Papalote, TX
That's right, now I remember, if he has only holes in the rear then the bracket has been removed, if he still has two the screws in place maybe it just slipped out somehow.
Again IIRC they are making that bracket aftermarket so might be tough to get a factory one, although there are allot more parts trucks than there used to be..
