Humvee Generator Pulley
Hummer Guy
823
United States Louisiana
Has anyone ever taken the pulley off the 200Amp generator? I try to use a breaker bar and a big crescent wrench to take it off but this thing is literally just frozen. Has anyone else ever taken this pulley off?
What I was trying, was putting my breaker bar in the back and then try to use my crescent on the front to loosen it
Maxjeep1
1,930
Las Vegas Nevada
That's what I was thinking
It has the procedure in the TM. I was trying to get mine off also. I was able to get the one nut off but I couldn’t get the smaller one off. It shows to clamp the pulley in a vise and I didn’t want to remove the beast. My pulley was not the issue and I’m glad I didn’t remove it.
Hummer Guy
823
Why are you removing it? And which pulley are you referring too? There are 2
This not my generator but its similar, its the 8 groove pulley. My generator wasn't making any power and was making a really loud sound as if something inside is broken. I bought a new generator but it didn't come with any pulley so I'm trying to take the pulley off the old one and install it on my new generator
nikojo
106
Wisconsin and Illinois
Why not use a pulley puller??
86humv
545
Texas
I looked up the $33 pully...Its for an early surp 100 amp alternator......belt won't line up.
600634 is what you need...look it up at macmotors...$$$$$
Retiredwarhorses
4,623
Brentwood, Calif
The nut comes off with an impact driver, the pulley will either come right off or will get destroyed trying, ive done about 100 of them, most common in the pulley will separate from the bearing, leaving just the bearing still stuck on the gen shaft, if the clutch action is seized, just buy a new clutch pulley
rossbart
49
Waurika, Oklahoma
I have an M1123 with s# below 196900. It has the dual voltage 200 amp Niehoff alternator. But, does not have the overrun clutch pulley. So, it chirps the serpentine belt when you kill the truck. And, just discovered I have one of the mounting bracket bolts broken off in the head (#13 on diagram). Don’t know if that stress contributed 🤷‍♂️
My question: does anyone know if I can upgrade the fixed pulley I have for an overrun clutched pulley? Part number If so, would it be the one I’m seeing listed for the M1114s? Be a good time to upgrade while I may have the alternator off.
Thanks for any help yall can give.
Retiredwarhorses
4,623
Brentwood, Calif
No, you have what’s known as a “pre-litens” pulley system,You would need to convert the entire system to “Litens” serp system as all the new trucks are.
This includes PS pump, reservoir, hoses, mounts etc…
Coug
4,824
Olympia/WA
For the sheared off mounting stud on the head, I had that issue and ended up changing to the newer style rear support bracket.
rossbart
49
Waurika, Oklahoma
Thank you so much for the info. Sounds like I’m stuck with the fixed pulley I guess.
I did see where Coug directed me to another thread and suggested upgrading the rear support to the later version which is, apparently, heavier duty and bolts direct to the block as opposed to exhaust stud. (#4 in diagram). I have ordered that and will plan to make that upgrade.
Is there anything else that can, or should be, done to cope with the fixed pulley situation in my application?
Thanks for y’all’s help…😊
