Source of M1009 starters?... and mounting hole issues
CP92
20
Brady, TX
Guys,
My starter started making a grinding sound when starting. The truck would fire right up instantly, but the starter made the screeching/grinding sound for the instant it takes to start the engine. I removed the starter and found a few things that concern me.
First, the mounting bracket was installed but the bolt holding it onto the block was not very tight, just pretty snug.
Second, there was one shim on the starter when the body says it's "no shim".
Third, one of the mounting bolts seemed to have semi-stripped threads, as did the threaded hole.
Fourth, there are marks on the nose of the starter that look like crack, but may be casting marks?
Here are some pics of the flywheel for good measure:
I'm not really sure what to think or where to go from here. Does anyone know of businesses here in Central Texas I can use if I need to replace the starter or have it rebuilt? I'm also wondering where to get new starter bolts and if the questionable hole needs some kind of attention.
Any advice y'all could give me would be greatly appreciated.
deank
693
Inverness, Florida
The bolts are easy on amazon
I do not know any shops in Central TX. I know you can get 24 volt gear reduction starters on amazon. I imagine that direct drive starters are available as well. Hillbilly wizard should be a good source as well.
found this online
CP92
20
Brady, TX
found this online
Thank you very much. I had a hell of a time trying to locate bolts, but I think I got some ordered from these guys:
They'll probably email me in a day or two to tell me they are out of stock and cancelling the order.
I'll get in touch with Hillbilly Wizard Monday and see what he says.
Thanks again.
CP92
20
Brady, TX
If you end up with a reduction drive starter. You will need the support bracket that goes with the reduction starter. They are not the same.
The HMMWV starters are also 24 volts and bolt to the same engine.
Here is a video about the different starters, starter bolts and support brackets:
Thanks for the video. I guess I'll look into MT28 availability too. Good info!
sbgarage
55
Wv
Make sure your flexplate bolts are torqued to spec. When I got my m1009 they were loose and the jamoke that owned it tried welding it to the TC lol
CP92
20
Brady, TX
I've been studying things a little and have questions.
I don't know what the mounting holes are supposed to look like, but it appears to me that mine have both been repaired with threadserts or something similar with the threadserts protruding out past the block's mounting surface (the far hole). The protrusion from the near hole came off on the bolt that was somewhat stripped...and the threads in the hole aren't in very good shape either (the near hole). Does this look normal to you or do you think I'm on to something?
The mounting surface on the starter is flat and has no recesses to work around the threadsert protrusions.
I think the shim was added to fill in the gap left with the starter resting on the threadserts instead of the block mounting surface. One of the holes in the shim has been enlarged to fit around the threadsert, but the other hasn't. I'm not sure what to make of that. The piece of threadsert that came off with the damaged bolt is shown beside the shim.
My plan is to use an Irwin M10 x 1.5 tap to chase the threads in the hole and hopefully restore them to take the 33 pound feet of torque. I'm wondering if I should grind off the protruding threadsert flush with the block and leave the shim out or leave the protrusion there and use the shim. What do you fellas think?
deank
693
Inverness, Florida
I agree, grind them flush, chase the threads. Rehang your starter without a shim, bolt up the bracket to the block and starter.
I have modified the the wire going to the solenoid on mine. I have a short wire going to the solenoid with a single wire weatherpack connector so I don’t have to fight the wire onto the solenoid.
I pulled the purple wire out the engine harness and routed it over to the fuel filter area. I had to add about 2+ feet to the wire.
CP92
20
Brady, TX
I guess we're on the same page, Guys. The M10x1.5 tap I ordered should be in Tuesday, so I guess I'll get started back on it then. In the meantime, maybe some others will add their thoughts. It sure makes me feel better about working on this thing when smart and experienced guys chime in and keep me from making dumb mistakes. Thanks, Guys.
Here's something I came across last night that might be an option at some point...a starter relocation kit form Leroy's Diesel:
