I have a M35A2C that I have not had any recent issues until now. A few weeks ago, I went to start the truck and when I turned on the accessory switch, the low air buzzer came on and when I pushed the start button, the truck would not turn over. I turned off the accessory switch then turned it back on and the truck started. When I went to start the truck yesterday I had the same issue, but then the truck would not start. It did not even try to turn over. I thought that it could be the batteries as they were several years old so I replaced the batteries. I turned on the accessory switch, got the low air buzzer then when I pushed the start button, still nothing. I turned off the accessory switch and tried to start again. Now I have no low air buzzer with the accessory switch on. It appears that I now have no power at the accessory switch. I am at 26+v at the batteries. I found some information in the TMs ref not starting and it indicated to check voltage at a few locations. I get no voltage at the locations that I checked. I can't locate any frayed or burnt wires. I do have headlights when they are turned on. I am not sure that I am checking the correct locations for power. I believe that the included pics are the starter relay and wire 74B.
Any assistance is greatly appreciated. Thank you in advance.
