Aftermarket "Plasa" CTIS Controller Not Functioning
Shakkles
23
IL
I've messaged the maker, Plasa on Facebook messenger and on here and waiting on a response, but since my m1078 is a daily driver and not sure how long i should expect for a response, i wanted to reach out here to see if anyone else has had the same or similar issue with his controller and maybe i can figure out what's going on.
So the controller reads, "OK ..." for highway "HWY" or any other setting you set it to, but nothing actually happens. Even with my tires now deflated all the way to 21 PSI, it still just keeps reading "HWY OK ..." but making no attempt to fill the tires with air. Unfortunately I don't have the PDF manual that originally came with the system and my attempts to reach out to various youtubers and so on who have the system and obtain a copy hasn't garnered any real results.
Does anyone have any experience with this issue for Plasa (Christian Platzer)s CTIS controller who might be able to advise, or perhaps share their manual so i can try and continue to self-diagnose the issue?
Thanks in advance.
hike
—realizing each day
945
Texas Hill Country
Are you in Auto mode?
On the display under AP you see "OK"? The system runs through the check: You can see "1" under C in the CID display?
GeneralDisorder
6,224
Portland, OR
Plug in a factory Dana controller, open up the Dana diagnostics software, and find out if the system actually works. You may have an issue with the wiring or the solenoids in the PCU.
And this is WHY I don't bother with that "solution" - it's unfinished. Has no self-diagnostic capability, and it's made from effectively proto-type parts in a proto-type enclosure. He has built, at most, about 100 of these units. It's not a finished product and has no real support. The Dana controller is widely available, has been built in the 100's of thousands of units (probably over a million), has great software, is environmentally sealed, and usually can expect 15-20 years of operation before they fail due to aging electronics. And with a couple wiring modifications you can unlock all nine of the predefined maps and also enable the "CTIS off" function that the truck was built to support (lamp in the annunciator).
I've removed three of the Plasa controllers from customers trucks after they either died or refused to help with diagnostics, or just were doing weird things - one was killed outright by a solenoid short circuit - which the Dana controller happily threw an error for AND remained undamaged as the driver circuits are appropriately designed with protection.
I would switch to a manual control scheme before using an Arduino based solution. Arduino's are fun for proto-typing and hobbiest uses. It belongs in the rear with the gear not in the cab of an Army truck subject to NVH, dust, moisture, dog hair, and whatever else. It's not appropriate for this environment - not in the format it's being packaged in anyway.
B-Dog
294
Denver, CO
Thanks in advance.
Is there an S at the end of the display? AP CID TER PSI S
When you start the truck, does the controller check the pressure "1" under C in CID - that would indicate that the controller is checking the pressure.
Follow the directions (manual posted above) for putting the system into setup mode (remove the jumper). Press & hold for a few seconds, Inc or Dec. Do you hear/see the relays inside the controller activating? Do you hear the solenoids activating in the control unit under the passenger side dash?
Report back.
GeneralDisorder
6,224
Portland, OR
Do you have a link to the Dana controller? I'm not familiar.
Dana made the system. I'm referring to the factory CTIS module. I personally have no beef with them.
The system is simple, yet seems complex to the uninitiated. The lack of complexity and sensors means it is incumbent upon the owner to understand the system and be able to recognize what the fault is based on careful observation and reasoning. It's only fault is that it doesn't like to hold your hand.
Plasa
341
Italy
Hello to all. Actually I'm not really on facebook anymore...
I agree that it's almost a prototype that now works for 5 years. I have still the first version of the controller and works.
If someone have a problem with one of my controller please write me a PM here, or even better, a email...
Christian
Plasa
341
Italy
And about debugging: There's a reason why in the controller is a usb cable. If you connect the arduino to a PC with the arduino ide open, you see all the telemetrics of the system, like status of wet tank, settings, pressures, valve status etc. So debugging is possible, without any special tools...
Christian
GeneralDisorder
6,224
Portland, OR
Christian
While some of us have experience coding and actually know what an IDE is, the vast majority would not understand the first thing about a development environment nor how to use it. It has a display and buttons - why doesn't the telemetry have a button combo so you can scroll through that information on the units integrated display? There should be no need to dismount it, open it up, and have a pile of wiring all over the cab just to see what it could easily tell you if the functionality was added.
The Dana controller has no display and given the end users it was designed for it is forgivable that it reserves this functionality for the service department. That's not exactly the type of user the Arduino controller is marketed for.
