mangus580
- 282
- 0
- Western NY
Your wiring looks like it has been adjusted at some point.
Yeah I was afraid of that. The original ground wire was broken off and the large ground wire was added. Why they didn't remove the eyelet and broken wire I have no idea! You can see the temporary end I put on the ground wire at the intake manifold in the far right of the pic. I want to replace the whole groundwire since the wire itself is slightly corroded.Your wiring looks like it has been adjusted at some point.
The small wire that wasn't making contact because of a dirty connection is the one on the left side of the plastic connector. The other wire coming out of the connector is a fusible link.The plastic plug has two 12v source wires, the one connected to the output lug is the exciter wire that excites the coils so the alt can create electricity and the other is sourced through the gen 1 light and the alternater provides a ground if there is a problem. if the wire connected to the output was disconnected your alternator would not charge your batt.
That would be correct...I have been doing some more studying and it appears there is suppose to be a black with white stripe wire on the ground post that is also part of the diagnostic circuit.
It looks to me like maybe someone replaced the plastic plug on his, that would explain why the wire colors dont match.
Bob, the dirty connection you speak of on the 2 wire connection would explain all your problems. That wire is what manages the excitation of the alternator, and that is handled through the Gen 1 light. I would get some contact cleaner, clean it up, and put some dielectric grease on it.
The small wire you have with the large red one on the stud... is as Michael says, a ground wire for the diagnostic circuit. You are lucky that you didnt short something out with it.
It sounds to me like the Exciter wire may have an issue some where in the Harness. Be sure the wire is good at the Alt. Hook up. I think I lost quite a bit of Hair this week with Glow plug issues. I finally changed one M1008 to manual and by using "THE card" from one truck and installing it on my other, I got the glow plugs to work good on Both trucks. Good luck, Phil
Wolf. I use the same configuration in my M715 said:A 6.2 in your 715? I've gotta read about that!
Anyway, I looked at Ed's (pc3nmcb) '09 and saw the brown wire that SHOULD be on the ground wire on my '08. Ed's is in the right place and mine soon will be!![]()
