EZFEED
- 0
- 0
- Lafayette, LA
Chris you give me hope!
Will - we oughta have it running pretty soon. We cranked it over while slaved on Saturday and the good news is that my wiring repairs to the cab harness held and there were no other surprises once we had a good protective control box. The cranking speed was even fast enough that the transmission pump starting dumping ATF out of a missing valve on the coolerI just wanna see/hear a vid of it running! Chris, I admire you for your dedication! That's ALOT of work.
You did a fine job on the wiring repairs. I had no doubts in your abilities, especially after all of your work on the 923A2 projectWill - we oughta have it running pretty soon. We cranked it over while slaved on Saturday and the good news is that my wiring repairs to the cab harness held and there were no other surprises once we had a good protective control box. The cranking speed was even fast enough that the transmission pump starting dumping ATF out of a missing valve on the cooler(a quick scrounge of the engine scrap pile found a suitable replacement).
Chad
I just checked my "truck notes" folder on my slaptop and found a reference for the Napa 4019 kit. It says that it comes with the filter base, fittings, and filter. I think they also offer filters with different levels of DCA precharge too depending on if you are going to run extended life or regular coolant in it...One thing I want to do is add a coolant filter to it. That should be easy since it has the fuel-burning heater kit on it. I'll just hook a remote coolant filter kit up to the existing fittings that were used for the hot-water personnel heater. Any suggestions on who to get a filter kit from? I think I have seen some filters that come pre-charged with coolant additives.
Good Lord, Chris - if this isn't done, what are you going to be driving to Aberdeen this year?Right Bjorn! Little bits at a time. I am not killing myself trying to get it ready for Aberdeen this year.
