What to do about GL driveshaft?
Mtrdrms
Torrington, CT
So what have you guys done about the bent driveshafts? Can they be repaired? mine doesnt appear to be too bad but does create quite the vibration around 30+. Where are you getting replacements?
Andy
m16ty
227
Dickson,TN
You could take it to a driveshaft shop and have them cut out the bent part and weld in new but I'm sure it would be cheaper to find a replacement. I would guess that a shaft off a civilain truck would work but I'm not sure.
319
Lieutenant
3,347
58
Michigan
Best to get it repaired or have a new one made. Civilian shafts are scarce and expensive.
Recovry4x4
LLM/Member 785
1,824
GA Mountains
I just had a shaft done for my Burb. only part reused was the yoke that goes into the transfer case. Spent $275.
87k5
Columbia SC
I just had mine done last week I to fell victom to the gov forklift. Got mine retubed, balanced and painted, and out the door for 152.00
rizzo
Port Huron, MI
Any driveshaft shop can reweld the ends of the shaft to a new tube for about $150.
Yep. Ye olde driveshaft shop! :-D
I personally don't believe in straightening one. Just have it retubed in my opinion!
I agree
CARNAC
The Envelope Please.
712
College Station, TX
Andy
I think I know someone that has one. I had gotten him a spare for a 1008 he was picking up and turned out GL hadn't bent the one on the truck.
Can you wait until next Friday?
saddamsnightmare
82
Abilene, Texas
January 30th, 2009.
Any driveshaft or better machine shop can repair your shaft. I had a 1989 Ford F250 that failed in the universal joint bearings and beat the shaft ends up good, so we cut them off and put 1-1/2 ton dumptruck joints on her for much less then buying new. Last I saw the truck (2007) she had over 325,000 miles, probably 175,000 after the repairs.
Cheers,
Kyle F. McGrogan:-D
avengeusa
MI USA
go to a speed shop, or a boneyard, you can find one of the center tubes for cheap, measure yours
50 bucks tops, and add a couple new u-joints
CARNAC
712
College Station, TX
No idea what the shipping is yet but the shaft was $100. He said he's willing to part with it if you still want me to pursue it.
