anti freeze
WillWagner
3,073
Monrovia, Ca.
Pre Charge...added at the place that makes the antifreeze, SCA...Suplemental Coolant Additives. Stuff added to the coolant to protect wet linered engines from liner errosion and it also helps protect the aluminum parts and prevent silicon drop out. Be aware, too much of a good thing can cause issues.
spentshell
Long Island NY
Its a little hard to explain but from what I can remember it helps stop cavitation which causes water hammer around the cylinders and can cause a leak. Somebody help me out here if this sounds wrong.
kurtze99
Du Quoin Il.
You can buy coolant additive(SCA) from most auto supplies. It will have the treat rate and also how often you should do it. I have seen some pretty bad pitting that was partially caused by lack of SCA in over the road trucks.
m16ty
218
Dickson,TN
Yes. Cummins are bad about it. I've seen it eat clean through the cyl.
Most coolant filters have SCAs in them and release it a little at a time. There's really no need in buying coolant with SCAs in it if your running a filter. It could be like Will says, too much of a good thing.
TenTires
225 RPM
50
Tidewater, VA
Or visa versa...If you dont intend to run a coolant filter, you could buy the antifreeze with the SCA's already added.
