Axle Nut Wrenches
DanMartin
17
Hillsboro, Oregon (USA)
The axle nuts need to be torqued to a specific tightness....that's why I just bought a 3" socket from NAPA, so I could use my torque wrench when re-installing the nut and getting the proper pre-load on the bearings.
Not sure how you do that with this style of axle nut wrench.
dm22630
42
Front Royal, VA 22630
They are? The 3" socket I have uses a regular 1/2" ratchet & I just tightened by feel. How many lbs of torque should I have used?
offroadchev
Banned
61
elkhart,indiana
I am aware of the torque requirement. However $10 is a good price compared to the price for a 3" socket. You should see the original wrench i made. Hand cut with torches. It worked but didnt look nice. I started by using a C clamp to remove them. I am of the school of thought "If you dont have it make it".
m16ty
228
Dickson,TN
The TM says adjust by feel then back off 1/8 turn. There are no torque specs that I found in the 209-20. Does the 361 series list a torque spec?
254
Wake Forest, NC
TM 9-2320-361-20
Page 9-11
1. Bend tabs back on adjusting nut washer (2) and remove outer adjusting nut (1) and washer (2).
2. Turn wheel, tighten inner adjusting nut (3) 50 lb-ft (68 NŽm), then back off nut (3) 1/16 to 1/4 turn.
3. Install adjusting nut washer (2) and outer adjusting nut (1). Tighten nut (1) 100-200 lb-ft
(136-272 NŽm).
4. Bend tabs on adjusting nut washer (2) down, over inner and outer adjusting nuts (3) and (1).
WillWagner
3,164
Monrovia, Ca.
TM9-2320-209-20-3-2, page 14-9, frame 4,
FRAME 4
1 . P u t o n a d j u s t i n g n u t , l o c k w a s h e r ( 1 ) .
2 . U s i n g w h e e l b e a r i n g n u t w r e n c h a n d s o c k e t h a n d l e , s c r e w o n l o c k n u t ( 2 ) .
U s i n g t o r q u e w r e n c h , t i g h t e n l o c k n u t t o 1 0 0 t o 1 5 0 p o u n d - f e e t .
3 . U s i n g h a m m e r a n d p u n c h , b e n d t a b s o f a d j u s t i n g n u t l o c k w a s h e r ( 1 ) o v e r
b o t h a d j u s t i n g n u t ( 3 ) a n d l o c k n u t ( 2 ) .
GO TO FRAME 5
Lex_Ordo
Long Island, NY
m16ty
228
Dickson,TN
FRAME 4
GO TO FRAME 5
Ok, you made a liar out of me :oops: ;-). I remember that now. Guess I was thinking about the adjusting nut.
The adjusting nut adjustment is what will cause bearing problems if not set right.
WillWagner
3,164
Monrovia, Ca.
No, no, not trying to do that, just hoped you didin't miss that tidbit, it could lead to not so good things happening! It is very easy to miss things in the PDF style TM's. That is why I am collecting paper now :wink:
papercu
33
Baxley, Ga.
What am I missing? Is there something in the paper copy that will come up and smack you if you miss it? The .pdf copies are the greatest things since grits. :-D Wayne
WillWagner
3,164
Monrovia, Ca.
I just find that on-line and PDF style things are tougher to find things in and follow procedures with. I've worked with both...now the electronic versions 99% 'cause that's what Cummins likes...and the paper is better IMHO.
