M113 weight
m113
vancouver bc
Hi everyone!
Does anyone know the weight ratio of alumnium and steel on a M113 APC from the 1960's? Any info is greatly appreciated!
Andy
WillWagner
3,068
Monrovia, Ca.
27.400 lbs for the M113 standard. Don't know the ratio. It is heavy!
Parker2
Plant City, Florida
27,400 lbs. wow!
I think we used the M113a3 maybe a1's (dont remember) when I was in the infantry in the '80s. If I remember right they were around 11,000 empty and around 14,000 lbs combat loaded.
papercu
32
Baxley, Ga.
The basis M113 is about 10.5-ton but I think the question is about the armor weight, ie. how much steel is in the armor plate?
The M113 was built of aircraft-quality aluminum which gives it some of the same strength as steel at a slightly reduced weight, as the greater thickness allows structural stiffness. Wayne
Nonotagain
Parkville, MD
Back in the mid 1980's the company that I work for built a composite M113. The hull was still aluminum, but all of the rest of the structure was fiberglass composites with ceramic for the armor.
I was able to use a 10 ton overhead monorail crane to lift the assembly so that I could drag the tracks under the vehicle and use a come-along to pull them together.
The M113 built by FMC would not stop a 30 caliber AP round. Our composite version with ceramic armor stopped both 50 BMG and Soviet 12.7 mm AP rounds.
