brake drum /hub rolling frame
Recovry4x4
LLM/Member 785
1,823
GA Mountains
I can muscle these around but not without consequence. I have a 5 ton drum somewhere in the palmetto scrubs that I use to keep me from buying a 5 ton. One tote of that drum and I lose all interest in the 5 tonners.
dittle
72
Albia, IA
When I pulled my hubs/tires I just used a wheel dolly and pulled it as one assembly (didn't remove the tires from the drum). Pull the axel, pull the wheel bearings and away you go with it. 20 minutes to from removal to re-installation (including repacking bearings and replacing all seals).
