- 574
- -21
- 18
so my horn doesnt work. i found that the wire coming out of the steering is broken. i started messing with it and pulled it a little and it was bare. i pulled it out about 6 inches and found it is bare the whole way. is this normal?? needless to say from me pulling on the wire now the button connection for the new style button is about 6 or 7 inches down the column
. what am i looking at to fix this wire?? i was thinkin of removing the 4 bolt collar and trying to remove the column from the steering gear but i dont want to pull it apart and really screw myself over if it wont go back together. i tried getting somthing down the column to try and pull the wire back but it doesnt seen to be working.
if the wire isnt supposed to be bare then im not sure why it would have burnt since that wire is essentially a ground wire off the negative side of a solenoid. if i take the horn wire that comes from the horn to the gear box connection and ground it the horn works fine.
![Evil or Very Mad :evil: :evil:](https://www.steelsoldiers.com/images/smilies/icon_evil.gif)
