panzerjunky
- 1
- 0
- san diego ca
Good evening fellas
Got My IP leak fixed thank the Good Lord for that one.
I have a small leak comming from the rubber? hose that links the steel tube from the bottom of my turbo to the mid drivers side area on the block what does this tube do and what matirel can I replace it with. also the short section of rubber tube comming of the valve cover breather to the road tube is this the same Mat. If not what is it and what can it be replaced with.
Thanks Again
Jerry
Thanks Again
Jerry
