M1009 water leak
alm0263
denton, Texas
My 84 m1009 has a leaky water pump. Anyone know the gasket part number? Or an easier quick fix?
It's leaking on the passenger side, out of the seal between the pump and block.
Thanks
papercu
33
Baxley, Ga.
If the water pump gasket is leaking, this is a good time to get a new water pump, hose, belts and change the antifreeze. Only thing you don't want to mess with is the thermostat, if there is no problem with it. Wayne
