Shark in tow
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Man, since I bought a CUCV, I need to get me one of those books! Any competent Standyne injection shop will have them. At least Ian knew that he could punch it out in a pinch. I should start rounding up all my core pumps and see what I have for spares.
lavarok
35
Fellsmere, FL
Kenny - I think the TMs were based off the book, so personally I don't think it is needed. Here are the pages which show the pump breakdown and related parts listing. These are from the 34P for the CUCV. Part 33 is the check valve.
jrou111
Birmingham, AL
That check valve is a fairly common part for most diesel shops. My 7.3 idi uses a Stanadyne DB2 which is very similar and my diesel shop had one in stock.
lavarok
35
Fellsmere, FL
Turns out the check valve in the return line on the top of the IP was bad.
I removed the check valve and tried cleaning it. No luck. I ended up punching the glass out of the center, reinstalled, and she fired right up. Its been running since...almost 2 hours now.
Now to find a source for new check valves! Here are some photos of the part and its location. These photos are from my parts engine since the photos were taken after I fixed the M1010.
As an update to this thread, I'd like to point out that if your check valve is clogging then there is a good chance the seals in your injection pump are going bad. It was only a few days after I installed the "cleared" check valve that my injection pump started to leak. I ended up having the injection pump replaced by Accurate Diesel in Orlando.
Low miles does not mean all the parts are ok! My M1010 had under 5000 original miles when I picked it up.
