NRG
- 1
- 0
- Medford Oregon
Howdy, I have read these forums for the past week trying to learn everything possible about the M35A2 i just bought. I went to go pick it up ( 740 miles away ) and everything checked out. Clean truck. But after an hour of driving I noticed some gear oil spitting up into the floor board of the cab. I figured.. it hasn't really been driven in 2 years so its just the seals getting wet again. Drove another hour and stopped. The tranny fluid is dumping out of the bell housing from the vent hole. I have read up on that, apparently that is very common if the transmission is over filled and you drive it on the freeway. When I pulled over and saw the tranny fluid coming out at a fast pace, I crawled under the truck. The transmission is hot.. like touch it with your finger and it will get your attention hot. I also noticed that the floor boards in the cab were pretty warm to hot as well when I was on the freeway. I had my mountain dew bottle sitting on the floor while I was driving in between the seats and it went from cold drink to warm-hot drink over time. Is the floor normally like this when you are running the truck at 48-50mph. I never got past 50 mph, so i wasnt running it "hard".
I limped the truck to a mechanic shop 9 miles away because I was freaked out about the transmission. I did notice that after letting it sit for 2 hours and then driving it to the mechanic shop 9 miles away, the truck was hardly leaking the transmission fluid. This makes me think that the tranny was just over filled ( which the guy I bought it from did say that he just changed the diff and tranny fluids ) and that is why its leaking all over the place on the freeway. There is no front tranny seal on these transmissions right? I did loosen the fill plug on the tranny and before I could unscrew it all the way out, tranny fluid was coming out, so it was way over full.
Anyhow, I think i'm at peace with the tranny leaking.. but the heat coming off the tranny kinda scares me.. is it normal? If it is.. I need to call that shop and tell them not to drop the tranny and charge me $850!
Thank you so much for your help and your expertise!
Truck Info:
1985 AM General M35A2 with 21,000 miles.
Truck Info:
