goldneagle
- 1,427
- Slidell, LA
My last major project on this M820A2 truck was the Super Single Conversion. Since I could not get the 1400-20 spare tire installed in the carrier behind the cab (due to its 550 pounds plus weight) I decided to use the space for other more desirable components. Since the truck has a liftgate I decided to install the spare tire inside the box in back. The liftgate makes it easy to get the tire in and out of the box in the back of the truck.
I decided to install 2 of the M818 tool boxes double stacked on the driver side and a 45 gallon vertical fuel tank on the passenger side of the truck. i also used the tool boxes as a support point for installing the 6200 BTU window A/C unit for the cab.
I started by removing the 2 tire carriers that held the spare tires in place behind the cab. I then removed the heavy angle frame that spanned across the frame of the truck. I welded some shallow Unistrut pieces across the frame to support the fuel tank as well as the tool boxes. After the paint dried i reinstalled the angle frame to its original position.
Unistrut is a U-chanel used by electrical contractors and plumbers to support pipes and equipment in commercial location. HILTI has the best selection of connectors and fittings that can be used with Unistrut.
I sanded and repainted the 2 tool boxes and then installed them in their new positions. I used some shallow Unistruts between the 2 tool boxes and they came out great! There are no exposed bolts so the tool boxes cannot be removed without getting excess inside them.
I installed Std. depth Unistrut behind the 2 tool boxes to use in supporting the A/C unit. I used a heavy duty Hilti brackets made for Unistrtut to support 2 horizontal Unistrut that will support the A/C unit from below. I cut and installed two 15" Unistruts on top of the horizontal that the A/C unit would slide and sit on.
I cut a 18 1/2" by 12" opening into the back window of the soft top. I installed an angle piece with 3/8" allthread attached. I lifted the A/C unit into place and secured it. I then installed another angle piece with allthread attached to it on the other side of the A/C unit. I took a piece of shallow Unistrut and ran it between the 2 allthreads to secure the A/C unit into place.
Thats all I got done so far... More tomorrow...
