chevyrac66
- 2
- 0
- Littleton, CO
Well guys today we (Rooster87, 101coolcars, and I) painted one of our M1009's with waterborn CARC Today. We used F93B505 Black, F93G504 Green, and F93N505 Brown. Which meets MIL-DTL-64159, Type II. The product is made by Sherwin Williams. We started by preping a few of the dents. The only bad ones were in the tailgate where we repaired them and spot primed it. We covered them with a dry coat of CARC before we painted the whole vehicle to help with any future problems of bleed through or paint transparancy. We masked the vehicle in about 30 min and had it fully prepped within an hour. This was my first time spraying waterborn paints and I liked it! It looks really good in the booth and its super easy to apply! We got some new paint suits since the last post. They were awesome and kept all the overspray off of us. We made sure to use our respirators since this stuff is pretty mean, but overall it wasnt as bad in the paint booth as even regular paint, Guess thats the benefit of waterborn, less VOC released into the atomosphere. We started mixing the paint at a 2 to 1 to .5 ratio. Which is 2 parts base 1 part activator and .5 parts water. That's right folks water in your paint!!!! The paint smelled terrible and had begun to seperate in the can, so we called our Sherwin Williams supplier and they said its supposed to smell and to to mix it extremely well. We did a few quick spray outs on the back glass masking and we started right up! First thing I noticed was that waterborn paints cover extremely well and didnt run hardly at all! You really gotta hose it on to run! It laid down over the old CARC very well and had excellent coverage. It's extremely glossy at first but as soon as it begins to dry (5 min) it flattens out extremely well! It has a little bit of a texture to it which helps it look "flatter" per say. The colors looked better to me than the GCI stuff but the surface was a little bit more delicate even after "flashing" . Which means dry but not cured. It's not nearly as forgiving at flashed "regular" paint. It didnt leave nearly as much overspray on the adjoing panels and floor. We were even able to do all the camo with very little overspray that takes away from the camo'd look. No lines where we filled in the black and brown like with GCI, Only took one coat for full coverage on all colors! I am very impressed with this product! It was really nice to spray a new product for the first time with no problems! Here's some pics!! The first pic is 101coolcars (black suit) and I! Second is Rooster87 and I. The rest are pics of the product and the process! My camera died as we were wrapping up but hopefully tommorrow Ill get some pics of it finished and pulled out front tommorrow! Hope this helps with some of the questions about waterborn and CARC application for you guys!
		 .  If water borne CARC has isocyanates, you still need to use a fresh air respirator.
